Old 09-10-2013, 05:34 PM   #1
trasherseb
Drives: camaro zl1 black carbon sun roof
need advice for launch at dragstrip
hi I went to grag race in Italy and try to do my best but I m not really satisfied about my times
best is 12.7 and it seems that i don t launch the car well any advice is welcome
(manual trans with 18" MT at rear with 19psi pressure in it)
http://www.youtube.com/channel/UCjSqxwOrBvP6uf0s0FHAR9g
thanks
trasherseb is offline   Reply With Quote
Old 09-12-2013, 10:44 PM   #2
axnhose
axnhose's Avatar
Drives: 2013 ZL1
It appears to me that your not doing a good enough of a burnout to get the tires hot and sticky. That is why your 60' is horrible. Once you get the car to 60 foot, then 90% of the battle is done. The rest is just shifting fast, and keeping the car straight. I think Mickey Thompson tires require a descent burnout, but not over excessive. Since you have a M6 trans, get the tires in the water, put the car in second, rev it up, dump the clutch, and lightly hold the brakes so the car doesn't move. Once you see smoke in your rear view mirror, your good. You can also call M/T and ask about tire pressure, but 19lbs is a good starting point.
axnhose is offline   Reply With Quote
Old 09-12-2013, 10:52 PM   #3
CRAMOS78
Gig'em Aggies
CRAMOS78's Avatar
Drives: 1992 RS 6.0 LSA swap; 2015 Z28
that was hardly a burnout...
CRAMOS78 is offline   Reply With Quote
Old 09-14-2013, 05:02 AM   #4
trasherseb
thank you
you re right it was hard to get tires burning (was in first gear stupid me )
May I ask you question about launch control ?
Old 09-16-2013, 12:28 AM   #5
axnhose
axnhose's Avatar
Drives: 2013 ZL1
Sure
Old 09-17-2013, 08:02 AM   #6
trasherseb
I tried the launch control but seemed to not working :
nanies of, mode 5, first gear engaged, wheels straight, and when I accelerate it stays at 5000 rpm (seems too high for me, is n it ?) and when I launch it spins a little and the engine cut down the power.....
I watch many videos read and read again the process I don t see where I do it wrong. Do you have an Idea?
thanks
Old 09-17-2013, 10:18 AM   #7
G Money
G Money's Avatar
Drives: 2013 ZL1, 2016 Denali HD
thanks
Nannies must be on and the accelerator pedal must be all the way to the floor and should stabilize the RPMs after a few seconds....
G Money is offline   Reply With Quote
Old 09-17-2013, 08:16 PM   #8
trasherseb
Thanks
Old 09-26-2013, 04:11 PM   #9
carfansince73
carfansince73's Avatar
Drives: Carefully
Originally Posted by HRD_WRK View Post
Manual cars:
[I]BURNOUT - The burnout for a manual car will work best if you start in 2ND gear.
Learned something new today.
After learning to drive stick decades ago in a Honda 4 cylinder, the thought of trying to do a burnout on purpose in second gear never occurred to me. I've done a second gear burnout on accident after not shifting into first at a stoplight and just giving way too much gas (remember, never had a car with this much torque before..) . I have to say I was laughing at all the smoke the people behind me had to go through. Like I said, that was not on purpose.
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; MGW short shifter; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!!
2014 CTS-V Sedan, Black/Black, Auto, Recaros, Ultra-view, Red Brembos. Stock
carfansince73 is offline   Reply With Quote
