Old 09-16-2013, 12:00 AM   #1
PMJ
Seeking 9s on M6...
PMJ's Avatar
Drives: 2012 2SS/RS LS3 aka "BlackWidow"
ZL1 one wheel burnout problem?
Any ZL1s having 1 wheel burnout issues? I occasionally had this on my SS stock diff, but did not expect to have it when I upgraded to the ZL1 driveline.
I'm curious if this is a known issue, and there's a solution... Or did I get a bad diff?
PMJ is offline   Reply With Quote
Old 09-16-2013, 09:30 AM   #2
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Your the first I have heard of anyone having issues with the rear.
Post back when you figure out the issue.
Trackman is offline   Reply With Quote
Old 09-17-2013, 10:33 AM   #3
nxttruck2002
Drives: Camaro
I'm sure the ZL1 has a rear diff
nxttruck2002 is offline   Reply With Quote
Old 09-17-2013, 10:40 AM   #4
Evotion
Warehouse 13 Survivor!!!!
Drives: '13 ZL1 - 69' Camaro
Evotion is offline   Reply With Quote
Old 09-17-2013, 06:40 PM   #5
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 18 ZL1 A10 & 18 2500HD Duramax
Never had that problem with my ZL1 but always happen to my 2010 SS M6.. Never knew why it did that.
Procharged 2018 ZL1 A10
2018 2500HD Duramax
TripleBlkZL1 is offline   Reply With Quote
Old 09-18-2013, 08:08 AM   #6
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
I know both my rears spin but I seem to wear out my right rear quicker.
joes407 is offline   Reply With Quote
Old 09-18-2013, 08:29 AM   #7
PMJ
Seeking 9s on M6...
PMJ's Avatar
The beginning of the video shows my problem. Looking closer, the water box was dry my first time through.
Old 09-18-2013, 09:18 AM   #8
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Same for me, just got new Michelin's to put on and the right rear was worn down more.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 09-18-2013, 11:56 AM   #9
nxttruck2002
Drives: Camaro
Originally Posted by Evotion View Post
Doesn't the ZL1 have an LSD to prevent this?
Old 09-18-2013, 12:05 PM   #10
PMJ
Seeking 9s on M6...
PMJ's Avatar
Yes, but apparently I have the only one not performing as designed.
Old 09-19-2013, 05:41 PM   #11
SPOOKYGUNNER
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT
I HAVE AN A6 AND CAN'T GET THE TIRES TO BREAK LOOSE TO DO A BURNOUT!!!. HAVE NO DESIRE TO CHANGE THE TORQUE CONVERTER.
ANY IDEAS HOW I CAN HEAT THE TIRES UP?
SPOOKYGUNNER is offline   Reply With Quote
Old 09-19-2013, 06:09 PM   #12
syn-ack
Drives: 2013 Camaro 2SS/RS L99
Umm, if the tires aren't breaking lose trying to do a burnout, why would you need to heat them up?
syn-ack is offline   Reply With Quote
Old 09-19-2013, 07:54 PM   #13
ZL1RHINO
Drives: 2013 black on black
I would say just make sure traction control is off.
ZL1RHINO is offline   Reply With Quote
Old 09-20-2013, 11:56 AM   #14
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I would try to change the rear diff fluid. I suspect it has something to do with the friction modifier in the fluid. You are getting a lot of bite from those tires but the dif should still lock it up.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
