Old 09-16-2013, 03:31 PM   #1
Meister
Meister's Avatar
Drives: 2016 Corvette Stingray Z51
Don't buy JL Audio from non-authorized dealers
Just a word of caution to anyone contemplating the purchase of any JL Audio equipment. I bought a brand new set of JL C2-650 component speakers from Amazon. Thought I got a great deal at $112 plus shipping. Everything seemed great with the purchase but I discovered that the driver side tweeter was not receiving a signal from the crossover unit. I verified that the crossover had no output at the tweeter connections with a multifunction meter. Contacted JL Audio to see about a replacement crossover. No luck. They will not honor their equipment for ANY warranty coverage if it was purchased through a non-authorized dealer. I can't even buy just one replacement crossover unit. I have to buy the whole damn set. At my local "authorized" dealer that will run me $200! What a PITA! Buyer beware.
2016 2LT Corvette Stingray Z51 7MT:
Torch Red, Adrenaline Red/Black interior, Nav, PDR, black wheels, Carbon Flash trim.
Current mods: Permagrin!
Meister is offline   Reply With Quote
Old 09-16-2013, 03:47 PM   #2
oachalon
Drives: 2010 Camaro 1SS
Open up the crossover, might just be a bad solder joint or as simple as a bad cap. You can probably see who makes the cap, inductor, or resistor and get a replacement dirt cheap and fix the issue if you have some soldering skills.
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno.
oachalon is offline   Reply With Quote
Old 09-16-2013, 04:22 PM   #3
Meister
Meister's Avatar
I am solder challenged. Thanks
Old 09-16-2013, 05:48 PM   #4
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
But I bet if you ask around, you'll find someone who isn't.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 09-16-2013, 06:02 PM   #5
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
It's usually common knowledge about the warranty deal. Any electronic repair shop should be able to fix that or let you know what's wrong with it. I wouldn't stress out over it.
Deftones is offline   Reply With Quote
Old 09-16-2013, 10:42 PM   #6
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
This applies to any hardware (not just JL and Amazon). You always need to verify warranty information.
As for Amazon, it varies by the reseller that you choose during checkout. Some of the resellers on Amazon are authorized.
JimE is offline   Reply With Quote
Old 09-17-2013, 01:15 AM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you could get a aftermarket warranty. squaretrade is cheap. I think they are good for 30 days after purchase.
JCunningham is offline   Reply With Quote
Old 09-17-2013, 02:35 PM   #8
Double D Mods
Double D Mods's Avatar
Drives: 2012 Grand Sport Convertible Vette
We are authorized
Double D Mods is offline   Reply With Quote
Old 09-17-2013, 07:26 PM   #9
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
Why don't you contact the seller? If the sold you something that doesn't work then they need to replace it.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 09-17-2013, 10:10 PM   #10
Meister
Meister's Avatar
I am going that route right now. They say they will replace the defective part. We'll see.
Old 09-18-2013, 07:41 AM   #11
baum
Drives: 2013 1LS, 2013 Ram 1500
Originally Posted by Double D Mods View Post
We are authorized
So i can go through JL or do i have to go through you if i purchase from you?
baum is offline   Reply With Quote
Old 09-18-2013, 09:49 AM   #12
Meister
Meister's Avatar
You just need to confirm that you are buying from a JL authorized dealer in order for warranty to be honored. That information is available on the JL Audio website. Double D Mods indicated they are an authorized dealer.
Old 09-18-2013, 09:52 AM   #13
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Bought 600$ of stuff from a Rockford dealer, tweeter crossover only worked for 5 minutes (didn't even hook it up to an amp) had to contact eBay buyer support and make a case to get my money back on the tweeters and I told the dealer I will return all products purchased from him.
Knockoutpie is offline   Reply With Quote
Old 09-18-2013, 01:33 PM   #14
Double D Mods
any issues on any othe products we have to get an RA number from JL as they will check serial number from our invoices to make sure it was purchased from us. Each item has its own serial number that is then marked on each invoice we get billed for. Most companies do this.
We would then email you a return label with the RA number on it to send direct to JL for warranty claim.
With our RA we give you to put on BOX, copy of RA to place inside the box, and on the shipping label itself JL would know exactly what to do with the item when received.
This is how we handle any issues
Dennis
jl audio, speakers
