Old 09-18-2013, 09:58 AM   #1
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
NPP Stealth mode - added factory & wild modes
although probably not a common occurrence, i wanted to have the dual mode exhaust closed at idle. i came up with the attached fix. there are many ways to skin this cat, i chose this one because it worked for my needs and thought others could get some ideas from it.
There have been several posts looking for a method to have three NPP modes incorporated into a single switch.
Stealth – exhaust flappers closed all the time
Factory – flappers operate as per the factory parameters (more below)
Wild – flappers always open
I created a second DIY to show one way to do it
h018871 is offline   Reply With Quote
Old 09-21-2013, 09:17 PM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Thanks again for the DIY How To man...
Firefighter is offline   Reply With Quote
Old 11-18-2013, 03:11 PM   #3
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
BUMP
tramtwo is offline   Reply With Quote
Old 12-14-2013, 06:36 PM   #4
wessolbuf1
wessolbuf1's Avatar
Drives: 2014 Camaro 1LE Summit White
great write up thanks.
Ordered 10-1-13
TPW- 10-28-13
Delivered 11-12-13
wessolbuf1 is offline   Reply With Quote
Old 02-23-2014, 03:47 AM   #5
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Single Switch, 3 Modes UPDATE
edited first post to add a DIY for a single switch controlling 3 modes
Stealth
Factory
Wild
Old 02-23-2014, 11:16 AM   #6
Firefighter
Sweet, now I really want to do this. There is nothing more to want for this mod... Thanks again man.
Old 02-23-2014, 02:49 PM   #7
Brandonmos
Brandonmos's Avatar
Drives: 2013 1SS 1LE
I wish I was more electrically adept
Killed so many water bottles that day...
Brandonmos is offline   Reply With Quote
Old 03-04-2014, 10:59 AM   #8
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Agreed, this is so awesome but I have no electrical knowledge or comfort. Sadly I think I will stll end up dropping $200 for the ADM controller, and will only have 2 functions.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-15-2014, 11:41 PM   #9
Inferno1LE
Inferno1LE's Avatar
Drives: 2013 Inferno Orange 1SS 1LE
Alternate Method
Hey, I don't mean to put you down, you did a great job figuring that out and it will work perfectly that way, but there is a much simpler way to accomplish this.
You can cut the blue/yellow wire going to the rear fuse block, and wire in an on/off/on rocker switch. Here is a crude diagram of how I wired my NPP.
When you're done, the 3 positions will be flaps Closed/Open/Normal.
Inferno1LE is offline   Reply With Quote
Old 04-16-2014, 07:08 AM   #10
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Brilliant!
i did not think of that method, much cleaner.
Old 04-16-2014, 09:31 AM   #11
Firefighter
Okay... so my electrical experience is limited but how does this last method work? You have one wire that you interrupt. I assume you cut it then a three position switch with an extra ground... how's that make this happen?
If it works I'm all for it b/c cheap and easy. I would like to understand it more though.
Sent from my DROID RAZR HD using Tapatalk
Old 04-16-2014, 12:11 PM   #12
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
UNMODIFIED: When the controller is energized it grounds the valve relay to close the exhaust.
Inferno1LE's mod: position 1 acts like factory, position 2 opens the wire so the relay stays open, position 3 connects the relay to ground.....putting the relay on all the time
Sweet & simple solution. Kinda embarrassed that I didn't think of it
Old 04-16-2014, 05:10 PM   #13
Firefighter
Sometimes we get so involved in our original idea we forget to think of another path.
So verdict is both methods work?
Old 04-16-2014, 10:32 PM   #14
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Yep
They should both work............ Simple or Goldberg method-->same result
dual mode exhaust, npp, quiet exhaust, stealth exhaust
