![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
What are your tunes setting redline at?
What are your tunes setting redline at? Is there any power to be had a little higher in the rpm range with stock springs?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Oct 2011
I think I am at 6500 or 6600. no issues yet. 7k on the clock.
I like the power band better with more RPM.
2016 2SS
2020 super duty on 37's |
Cool. I'm sure there is some sustained power left on the table a little past 6000.
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
6800rpm but I set my shift light for 6600rpm. I like this setting, I never bounce off the rev limiter this way
6800 with stock springs?
#6 |
ANGRY Z
No. Comp cams dual valve springs with titanium locks
#7 |
Catfish
Drives: 2012 Camaro ZL1 #361 Join Date: Nov 2011
6700 w/ stock springs
2012 ZL1 VIN# : 361
Victory Red, Alum Wheels, Manual, Carbon Fiber Mohawk Performance Mods to Date: Rotofab cold air intake, Kooks 1 7/8" LT headers w/ Calico KoolBlack ceramic coating, Kooks high flow cats, Corsa 3" X-pipe cat-back exhaust, 160 degree thermostat, 2.50" Supercharger Pulley, PCM Catch Can, Rotofab Supercharger Reservoir, 1000cc Injectors, MSD Boost-a-Pump,Tuned by PCM of NC 604 RWHP & 622 RWT !! Also, 2001 Silverado Z71, Pewter w/ Extended Cab & 2013 Chevy Cruise LTZ/RS White |
#8 |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro's, always have, always will. Join Date: Oct 2010
#10 |
I want to take it a little higher. 6400 or so. But not any higher.
#11 |
ANGRY Z
#12 |
![]() ![]() ![]() ![]() Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
I'm shifting at 5700ish. Seems a bit low but it goes.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Mar 2013
Well my car is an auto and it shifts with all the nannies off at 6000. With them on at 5800. I must need a tune or something. I have always thought it could go a little further. If I paddle shift it 6 grand is the limit cause it hits the rev limiter at 6100.
#14 |
![]() ![]() Drives: 2013 ZL1 Join Date: Oct 2012
you got a 10.1 by shifting at 5700rpms? dude shift at least at 6500rpms.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1 |
