Old 09-20-2013, 10:00 AM   #1
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
True Trac or JRE mod?
At the drag strip with drag radials I have noticed a moan sound coming from the rear end during burnouts. Someone said one tire is hooking up while the other spins while coming out of the box. So I am looking at an upgrade with gears in the near future.
I also run autocross and track days, so I don't want a posi that is going to shoot me sideways coming out of corners under hard acceleration. Can someone tell me the pros and cons of the JRE mod and True Trac set ups?
Cuda7050 is offline   Reply With Quote
Old 09-20-2013, 10:23 AM   #2
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
I have the True-Trac & 3.91's, I have not found any "cons" to it at all, it's great!!! Can't tell you much about the JRE Posi-Mod, never had it.
blazzin1 is offline   Reply With Quote
Old 09-20-2013, 10:30 AM   #3
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
also, call True Trac support, I spoke to the tech yesterday and he is very helpful. He did an article on the truetrac in a camaro for LSXtv
http://www.lsxtv.com/tech-stories/dr...ro-ss/?print=1
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 09-21-2013, 12:05 AM   #4
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
That's good information, thank you. Do you think with gears you picked up .25 in the 1/4 mile as indicated in the LSXTV article?
Old 09-21-2013, 01:30 AM   #5
Synner
Drives: cars
JRE mod is way too tight for road course/autocross.
Old 09-21-2013, 09:19 AM   #6
Merc
In The Circle
Merc's Avatar
I agree been down that road and I'm just in the process of putting a 12 bolt Hammerhead in Pumpkin.
Old 09-21-2013, 09:35 AM   #7
Supercharged SS
Drives: 2010 Camaro
That's not gonna happen so don't get your hopes up.
Old 09-21-2013, 09:38 AM   #8
Supercharged SS
Drives: 2010 Camaro
JRE posi mod works every bit as good. I've taken it into the 9's with no problems.
Old 09-21-2013, 12:34 PM   #9
Merc
In The Circle
Merc's Avatar
I've chipped teeth off the spider gears in the stock one and the JRE modified one. As far as I'm concerned the stock carrier unit is the weak link and I have two broken diff's to prove it. I believe if I had of put a Trutrac in with the gears, JRE caps and LPW cover I wouldn't be putting in the 12 bolt Hammerhead that I'm in the process of doing right now.
On the bright side my end goal is 650hp NA and with the 12 bolt Hammerhead in my diff issues are over.
Old 09-21-2013, 12:37 PM   #10
Supercharged SS
Drives: 2010 Camaro
You shift it yourself, I don't. I think that's where the problem lies.
Old 09-21-2013, 12:51 PM   #11
Merc
In The Circle
Merc's Avatar
I do it the old fashion way with a stick. Pumpkin is LS3 M6 and that's probably why I'm hard on diff's. Not to mention 4800 RPM launches.
Old 09-25-2013, 02:36 PM   #12
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
For what its worth, I thought I would share mainly for the SoCal folks, I got a quote of $1,675 for a TruTrac and 3.91 gear installed in my car from Unitrax of Anaheim. Seems like the way to go for me.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Old 09-25-2013, 02:39 PM   #13
blazzin1
blazzin1's Avatar
Seems like a "reasonable" price. I would add in the JRE billet caps while you're in there!!!
Old 09-25-2013, 03:33 PM   #14
IneedAZ
IneedAZ's Avatar
I decided to start all new...ordered another set of 3.91, new pinion and side bearings, shims, crush sleeve and nut, and the new TruTrac, BMR bushings, and a new place to install it. I know it takes an hour to take out of the car and an hour to install. My guess its another hour on the bench. Then there is the unplanned issue time. So i figure 4 hours total based off my last few removals and installs. New place quoted me $250. They said they gave me the cheaper labor rate for Hot rods, so he is applying that rate to mine. I am so over the cluthes in the factory LSD unit...grinding and popping all the time. Parts and labor around $1300 on top of the $2000 i paid the original place plus 4 trips there and issues each time.
