Old 09-23-2013, 09:29 AM   #1
trasherseb
Drives: camaro zl1 black carbon sun roof
Who's running kenne bell 2.8mammoth kit
hi, it s supposed to:
ncrease stock 580HP (466RWHP) to 710 (570RWHP) with automatic trans. HP nos. higher with manual trans car.
• Higher HP, low restriction 168mm rear inlet. No restrictive manifold driveshaft or jackshaft as with front inlets.
• 2.8 vs. 1.9L (47% larger displacement). 3.6, 4.2 optional (90-120% larger displacement).
• Optional LC (Liquid Cooled).
• Larger intercooler/cooler air charge.
• Standard MAMMOTH® Cool Air System (1200HP rated) =30-50HP over stock Zl1 with hot air.
• Eliminates stock hot air underhood snorkel (stock air box air flow is limited, so snorkel is punched in air box.
• 2.8 fits under stock hood (strut tower brace must be removed).
• 3.6, 4.2 require aftermarket hood.
• BOOST-A-PUMP® included.
• No cheap plastic engine covers to hide supercharger.
• KB factory tuned with MAMMOTH® Inlet. No expensive inlet upgrading or re-tuning required.
trasherseb is offline   Reply With Quote
Old 09-23-2013, 07:03 PM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I think you would be better off with a whipple.
MODS:
Old 09-24-2013, 12:16 AM   #3
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
ITS easy to get 600rwhp with the stock blower why spend all that extra money ? If all your going to get is 570rwhp,thats just a couple of bolt on's and your done,plus your not completely changing what the car is.
plus KENNY Bell has terrible customer service I mean really bad. If you have a issues good luck calling them and getting them to answer. go ask any shop,if they are telling the truth they will tell you it sometimes takes days to get through.I have dealt with it myself before,as well as the shop I was dealing with told me the same thing and i didn't listen. I loved the look ,but paid the price when my car sat for months waiting on bell to take care of the issues
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 09-24-2013, 12:21 AM   #4
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 18 ZL1 A10 & 18 2500HD Duramax
Dude... You can get 570rwhp with just bolt on's....
Procharged 2018 ZL1 A10
2018 2500HD Duramax
TripleBlkZL1 is offline   Reply With Quote
Old 09-24-2013, 08:48 AM   #5
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
I got 552rwhp with just a 8.6" lower pulley. Without a tune.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 09-24-2013, 09:07 AM   #6
TripleBlkZL1
Very nice!
IMO there's no need to spend all that money for a new blower just for 570rwhp..
2018 2500HD Duramax
Old 09-24-2013, 12:25 PM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Unless you want more than 750whp and are prepared to replace the entire bottom end with reinforced and forged components I would not replace the supercharger.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 09-24-2013, 01:17 PM   #8
ZL1-V
Drives: 2013 Camaro ZL1
Stay away from Kenne bell. I dealt with them in the 90's and they are terrible at customer service and support, always have been. I drove by their shop awhile back and it's still there. Good luck you'll need it if you don't listen to the advice given by myself and other members here on the forum.
ZL1-V is offline   Reply With Quote
Old 09-25-2013, 10:43 AM   #9
trasherseb
thanks for your answers
Old 09-25-2013, 05:42 PM   #10
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
i have a kenne bell lolLuckily there was another Camaro5 member that traded my car in at dealer and I picked up the fine tuned bad boy. I keep seeing that they have bad customer service, thats a shame because they look real good.But yeah If I were to install a S/C on a fresh new car I would prefer the magnuson.
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 09-25-2013, 05:58 PM   #11
hognutz
hognutz's Avatar
Drives: 2013 ZL1
my .02 is depending based on that hp goal it is not worth it. 600whp manual and 575whp or so auto is just too easy to hit witht he stock equipment.
I mean upper, lower, CAI, ported snout, TB, injectors, would get you past that.
half the money, a bit less labor, keep you strut tower. now you iat2's might be better with the KB so depending on your goals how long you want to sustain higher boost level you might want to consider it.
you could always do Zr1 cam and headers as opposed to both pullies and hit those targest at say 11-12psi with the stock blower as well though.
I just can't justfy the 6k.
thats $2500-3k depending on where you buy the parts. if you add headers the cost will just up to 3000-3500.
now forge the bottom end and I tottally see the the desire to put a larger blower on.
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
