09-25-2013, 07:09 AM | #1 |
Drives: 1LE Join Date: Jul 2011
6l50 overheat and Dtc
Hello!
After tracking the car for 20 minutes the DIC reported a temperature of 111 Celsius (230 ish Fahrenheit) and threw some codes and lost power + problem lights on the cluster. Codes are : P0634 u0101 p0700, they are tcm temperature related. The car was on the hypertech tune at 25% shift firmness and rev limiter cranked all the way up, driven to the limit in sports mode. Mods are mrt axleback, intake insulator, ported intake manifold, airaid Cai, and the tune + elite catch can. After being escorted to the pit I removed the tune and cleared codes, seems fine now. Could the transmission be damaged? Should I change the fluid? What fluid is best? Also, would a colder thermostat lower those insane temperatures at the track? Any input would be appreciated, It would be a shame to damage this car. Thanks to you all. Sent from my Nexus 4 using Tapatalk 2 |
09-26-2013, 10:28 PM | #2 |
bump. anyone?
Sent from my Nexus 7 using Tapatalk 2 |
09-26-2013, 10:58 PM | #3 |
Drives: 2012 2ls Join Date: Sep 2013
Back the fill plug out just alittle and get a sample of trans fluid. Does it smell burnt wipe it on a white paper towel is it black or reddish
Dexron 4 is a very good trans fluid You went into limp mode so thats good Maybe get a remote mount trans cooler there easy to install and you can also add a extra fan so when your at the track just flip a switch When I use to track my old 02 SS I removed the cowl seal at the track that really helped my temps dropped by 40 degrees
2012 Camaro 2ls DD
1987 Camaro sport coupe lsx forged internals (in progress) 1994 GMC sierra 360 sbc ported intake and TBI big block injectors (tuned) Last edited by thirdgenlsx; 09-26-2013 at 11:11 PM. |
09-26-2013, 11:09 PM | #4 |
Drives: 12 SIM 2SS/ RS Sinergy M6,GMC2500HD Join Date: Jan 2012
If you are going to track it you will need a external transmission cooler to start with!!!
09-28-2013, 07:02 PM | #5 |
thanks guys, any opinions on what cooler would be good with stock radiator? (I assume the lines will be re-routed to the new one... ) ?
10-03-2013, 07:42 PM | #6 |
TRI-COUNTY CAMAROS
Drives: 2SS/RS Oct 2009 Join Date: Oct 2009
I used the B&M hi-tek cooler (the big one) it has a fan fitted. And yes I re-routed the lines from the rad.
I don't race, but the temps are cooler, < 180, and never go above on spirited driving and im in South Florida.
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next?? |
10-03-2013, 08:11 PM | #7 |
I ordered the fanless flex-a-fit cooler. Should I re route even without a fan?
10-04-2013, 06:50 AM | #8 |
TRI-COUNTY CAMAROS
I'm really not best placed to answer that. I'm no expert. But it won't hurt to leave it routed through the rad first then to the external cooler.
My theory would be coolant enters the top of the rad, by the time it has any chance of convection to the bottom where the tranny cooler is, it should be at a lower temp than the transmission fluid. The bottom of the rad also gets a good air flow. I think in your case i would leave in line. This is one of those you will likely get different opinions.. Good luck
10-04-2013, 09:32 AM | #9 |
Thanks for your honest opinion!
