Old 09-26-2013, 10:29 PM   #1
manu_b
Drives: 2010 Camaro inferno orange 2LT RS
Why exhaust sound deep during cold start?
As question title says , why does it happen? I just put on NPP and first time when i started it, I was amazed by the deep sound but then it went little quite.
manu_b is offline   Reply With Quote
Old 09-26-2013, 10:59 PM   #2
KMPrenger
KMPrenger's Avatar
On cold startup, the car runs the rpms a bit higher than normal idle and I also believe it purposely runs a bit rich. This is to help heat up the catalytic converters quicker....so basically it is strictly for emissions purposes. After 30 seconds or so, it idles normally.
Old 09-27-2013, 09:27 AM   #3
manu_b
There should be a way to make car perform cold start every time. Or run it little rich under 1000 rpm
Old 09-27-2013, 09:56 AM   #4
ZL575 #26
Drives: 2010 ZL575 Camaro 2SS/RS
That sound at startup is invigorating.
ZL575 #26 is offline   Reply With Quote
Old 09-27-2013, 10:09 AM   #5
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
It has always done that, but it was less noticeable with the stock exhaust. Both my 2010 and 2012 have always done it. It's just the cold start mode, sort of like what carbureted engines had with an automatic choke. It makes a cold engine easier to start.
The Bird is the word!
