Old 09-30-2013, 09:55 AM   #1
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Changing the rear diff fluid
I'm going to be giving this a shot soon and would appreciate any tips (or if someone could point me to the best DIY on the forum).
A few questions:
  1. which brand of fluid is best
  2. can I get this at a local auto store, or do I have to order
  3. is it ok to do this with the rear wheels on ramps (will all the fluid drain out)
  4. I have the LPE 3.70 gears. Is the procedure still the same?
Thanks for any advice!
E.T. is offline   Reply With Quote
Old 09-30-2013, 11:25 AM   #2
Avenging Orange
Avenging Orange's Avatar
When in doubt, factory fluid will do. Yes you can do it on ramps. Some may tell you a tad more friction modifier for an aftermarket set, but I think you'll be fine. Search the DIY, all kinds of info there.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 09-30-2013, 12:02 PM   #3
E.T.
E.T.'s Avatar
Cool, thanks.
I found a good DIY on here. Someone said that it can be done without even jacking up the car?
I'm going to give the Royal Purple 75W-90 a shot.
Old 09-30-2013, 05:39 PM   #4
Avenging Orange
Ha, you can, but its a tight squeeze getting under there. I just used hydraulic jack and jack stands on drivers side. RP is a good choice.
Old 09-30-2013, 06:07 PM   #5
E.T.
E.T.'s Avatar
LOL, yeah, I just slid under there in the garage and it ain't happening with the jack. I'm skinny, but it's still real tight. So just raising the driver's side works well? Did you put one jack stand on the driver's side rear?
Old 09-30-2013, 06:17 PM   #6
rozay
rozay's Avatar
Drives: camaro 2LS LFX A6
I used redline
Niche 20x10.5, BMR 1.25 springs, GFX splitter,1LE Diffuser w/ 3.5 quad tips
rozay is offline   Reply With Quote
Old 09-30-2013, 07:25 PM   #7
SPCBA
Drives: pleather and Chiclets
Gonna need a simple hand pump (like from wifes lotion....or yours hehe) and a tube to go from pump spout to the fill hole. Real easy on ramps. Dont over tighten the bolts back in. Ask lpe what they suggest for fluid and friction modifiers would be my suggestion.
SPCBA is offline   Reply With Quote
Old 10-01-2013, 08:05 AM   #8
E.T.
E.T.'s Avatar
I'm good with the friction modifier (it's already in the Royal Purple). Is this okay to do with the back end on ramps or should the car be level?
Could I put the rears up on my race ramps, and then jack up the front to level the car and pop some jack stands under there? Or maybe this is making things too complicated...can I just back up onto the ramps and do the fluid change even though the car won't be level? I have a little hand pump I can use if all the old fluid doesn't come out.
Old 10-01-2013, 10:01 AM   #9
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
You can do it on ramps (I just changed mine this way Sat.) however the drain plug is towards the rear so not all the fluid will drain out so you won't be able to get a full quart back in when you fill up. The difference will only be a couple oz so it's no big deal. If you do it on ramps, don't drive all the way up on the ramps, only go about half way up and chock the wheels so you will get more fluid out.
Old 10-01-2013, 10:48 AM   #10
E.T.
E.T.'s Avatar
Cool. I also have jack stands, so do you think that would be the better choice? I wouldn't have to raise the cars as high, but I feel a little more comfortable under the ramps. Either way, I can pump out the leftover.
Old 10-01-2013, 02:09 PM   #11
E.T.
E.T.'s Avatar
Originally Posted by HRD_WRK View Post
I wouldnt recommend driving partially up a movable ramp and crawling underneath, even with front chocked and E brake on.
I change mine without raising it at all, but im pretting skinny with long arms.
Raising/lowering a rear end takes only a minute. jack it up on left side, put a stand under it, open the plug, lower it down to get it All drained out.
jack it back up on both sides(w both stands) to replug / fill.
Change when car has been off for a while.
Get a GOOD pump.
We assume you dont have an Eaton TT, else Id use different oil and no modifier.
Thanks, I will give that a shot. No TT (twin turbo?) just a Maggie
Old 10-01-2013, 05:16 PM   #12
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Tru Trac.
John B.
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-02-2013, 10:17 PM   #13
E.T.
E.T.'s Avatar
Well, it's all done. Wasn't too bad. The drain bolt was too close to the one exhaust pipe, so I had to unclamp it and move it a bit. It was a little tricky getting everything out of the new bottle and into the diff, but I got most of it in with just a tiny bit of spillage. Went for test drive and didn't notice any new or strange sounds, so I think it was a success
