Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 10-03-2013, 06:13 PM   #1
Macina
Drives: 2014 Camaro 2SS/RS 6MT AGM
Camaro SS vs Vette c6 ls3
Ive ordered a 2014 2SS/RS ls3 and im modding it with 1,7/8" LT headers w/o cats, cai inc cai, stainless works retro chambered cat back, sct x3 tune from janetty..
My best friend has a vette c6 -09 ls3 bone stock and we are constantly bashing about whos car will be the quickest in a straight line..
What do you guys think? Will I even have a chance?!
Both cars are MT.
Greets from Sweden!
2014 Ashen gray 2SS/RS 6MT, Black rally stripes, Recaros, Sunroof.
Mods: OBX 1.7/8" LT headers, No cats, SW retro chambered cat back, CAI inc cai, JRE Scoop, roto-fab wb relo kit, RX catch can, Vmax ported TB, 1LE steering wheel, 1LE shift knob/boot, SCT tuner, Anthracite plasti dipped wheels, Apex/Pfadt 1.25" lowering springs.
Macina is offline   Reply With Quote
Old 10-03-2013, 08:06 PM   #2
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
http://en.wikipedia.org/wiki/Power-to-weight_ratio
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 10-03-2013, 08:18 PM   #3
CryoMan10
CryoMan10's Avatar
Drives: 2010 2SS/RS
my vote is for the vette... my 07 ls2 will out run with my intake and full exhaust 10 SS
2010 2ss/RS.
Hurst ST
160T
Vararam Tune only version
comp cam 223/231 112lsa
Stainless headers 1 7/8
Stock H pipe no mufflers
solid subframe bushings
Hotchkiss stage 3 suspension
TSW wheels on NT05
3.91 gears
Nitrous outlet plate system.
CryoMan10 is offline   Reply With Quote
Old 10-03-2013, 08:20 PM   #4
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
Assuming everything goes well, your looking at 400-420whp with bolt ons and tune. Even if you upgrade suspension your probably going to loose. You weigh a lot more than he does (+400 lbs). Add a decent cam and ported heads and you can take him (if you want to claim N/A vs. N/A).
alaskacamaro is offline   Reply With Quote
Old 10-03-2013, 09:03 PM   #5
Deki
Deki's Avatar
Drives: 2018 Mustang GT
I think you should be able to take him. I'm only tune/exhaust on my GT and I have yet to lose to a stock LS2 or LS3 Corvette.
2018 Mustang GT
Deki is offline   Reply With Quote
Old 10-03-2013, 09:18 PM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Originally Posted by bluebeastsrt View Post
Vette will win assuming equal driver.
I have driven a stock LS2 vette and a stock LS3 and L99 camaro and the vette will take both of them without an issue. Adding those bolt ons won't change a thing thanks to the vette being so much lighter.
Old 10-03-2013, 09:20 PM   #7
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Is he manual? If he can drive an m6 he can hit 11's stock, you wouldn't stand a chance without a cam. If he can't drive you might have a shot
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 10-03-2013, 09:44 PM   #8
Deki
Deki's Avatar
Very few have hit 11s stock, and most I've seen on the fast lists on their forums are well into the 12s. I think with the mods he has, if the vette is stock, he should be able to take it.
2018 Mustang GT
Old 10-03-2013, 09:50 PM   #9
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Yeah reason why I said "if he can drive"...But I don't feel confident that op can take him regardless, unless op is an incredible driver himself...
Old 10-03-2013, 09:52 PM   #10
usnatclee
usnatclee's Avatar
Drives: '12 2SS/RS, '13 Vette, '13 Wrangler
To give you an idea the mods on my cars are listed in my signature. The Corvette best is 12.75 @ 114 in 90 degree heat and the Camaro best is 12.97 @ 109 in 100 degree heat. Both are autos and were spinning ALOT both off the line and at shifts. I hope that helps.
2012 Camaro Ashen Grey Metallic 2SS/RS "Timberwolf". Custom exhaust, RX oil catch can and oil breather, CAI inc intake, SLP 160* thermostat, TSP 2" LT headers w/ off road pipes, custom cam, tuned. 467rwhp 450rwtq.
2013 Corvette Torch Red LS3. 378rwhp/375rwtq SAE corrected, tuned.
ROCK CHALK JAYHAWK GO KU!
usnatclee is offline   Reply With Quote
Old 10-04-2013, 11:00 AM   #11
Rock36
I just like V8s
Drives: 2007 Corvette Z06
Good driver, and if you happen to be lucky enough to run a track that sees negative DA.
Rock36 is offline   Reply With Quote
Old 10-04-2013, 03:00 PM   #12
Macina
Sooo, basically im screwed then..
Guess im gonna have to start thinking of a cam package then... Maybe give him a year or something and then go for it.
Old 10-05-2013, 02:58 PM   #13
Rock36
I just like V8s
Just run him and see, everyone will have fun I promise.
Some five or six years ago I ran and skull drug a C5 vette with my 2005 Mustang GT w/bolt ons at the strip. Granted it was an automatic vert with a 2.73:1 rear end, basically the slowest C5 corvette ever made, but it was a blast all the same.
Old 10-05-2013, 03:51 PM   #14
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
+1 08 LS3s pull my 2SS by 4-6 cars and all I have is an intake, with the mods he listed that should about even out that 5 cars.
DarkneSS is offline   Reply With Quote
