Old 10-04-2013, 03:56 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
How much should i be paying for these jobs?
I am wanting to have my tranny fluid changed as well as my rear diff & having my separate clutch res installed and my system bled and re filled. Im contemplating on doing the rear on my and the new res but i dont exactly have the best setup in my one car packed garage to do it. How much should i be expecting to pay roughly to have these done?
Nighthawk89 is offline   Reply With Quote
Old 10-04-2013, 07:57 PM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Transmission fluid and filter change - I was quoted $150 at one shop and the dealer wanted $200. I verified that this was not a flush, a flush was more expansive. I decided I'm going to try and do it myself.
Rear Diff fluid - I was quoted $100 at both. I do this myself it's so easy.
Maybe someone else can chime in on your clutch res.
Old 10-04-2013, 10:21 PM   #3
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Popcorn
Sent from my iPhone using Tapatalk. If it is spelllled wrong, deal with it.
Crime2 is offline   Reply With Quote
Old 10-05-2013, 01:38 AM   #4
Nighthawk89
It looks like i am going to do my rear diff myself but the tranny ive been told should be done by a shop..
The res im not sure. Im trying to locate all of the lines to bleed the entire system or find some DYI on it..
Old 10-05-2013, 03:18 AM   #5
The Sandman
Flying Low & Raining 3's
The Sandman's Avatar
Drives: 2012 Camaro SS 45th Ann. Edition
I was quoted $230 to drop the transmission fluid from my dealer last week - I passed on it.
The Sandman is offline   Reply With Quote
Old 10-05-2013, 09:02 AM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
There's a couple DIY's on how to change the tranny fluid here on the forums. The M6 isn't that hard.
Old 10-05-2013, 09:52 AM   #7
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
Do it yourself if possible. I scoffed at the $350 my dealership wanted to charge me.
It was less than $100 to do it myself.
edgehead2000 is offline   Reply With Quote
Old 10-08-2013, 10:59 PM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
$100 to change rear diff fluid!!! it takes 5 min and only takes 1qt and 3oz of limited slip fluid.
JCunningham is offline   Reply With Quote
