Old 07-13-2009, 01:11 PM   #1
alex33x
Drives: 2013 Camaro ZL1
My engine shaking a little at idle.
I was wondering if anyone has felt this, this is my first ever GM car and I ask because, my 07 GT was very smooth back when it was stock you could barely tell it was on at idle.
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 07-13-2009, 01:12 PM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Mine does it as well .. idles around 500rpms and has a bit of a shake. It is normal ..
Crowley
Crowley is offline   Reply With Quote
Old 07-13-2009, 01:27 PM   #3
alex33x
Crowley
Oh thats good to know thanks, also since you have a twin of my car thers another thing I've been forgetting to ask, you know how the mirrors change to a greenish color at night?? Do all 3 mirrors do it?? cuase my passenger side mirror is not doing it. Just the center and driver's side.
Old 07-13-2009, 01:33 PM   #4
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I'm not sure as I haven't driven it at night much. I think I did see something posted about the inside mirror should auto dim and the drivers side mirror should auto dim .. however I could be wrong .. let me see if I can find that thread.
Crowley
Old 07-13-2009, 01:34 PM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Here you go .. check out this thread ..
http://www.camaro5.com/forums/showth...ghlight=mirror
Crowley
Old 07-13-2009, 01:34 PM   #6
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Shake is normal. You're at idle sitting on top of 426hp!!! Shake is good!!!!
Old 07-13-2009, 01:36 PM   #7
JewelZ
Just Lovin' My Camaro!
JewelZ's Avatar
Drives: CGM 2LT/RS/AUTO
I don't think that right sideview mirror changes, but I could be wrong. I don't see why GM would make em like that, I think the passenger side view should be auto-dimming as well, it's not like it for the passenger convinience it's made for the driver.
CGM( GRAY 2 tone interior ) 2LT/RS/AUTO
NJHKKM $29,965.00 1EH37 1100 03/28/2009 AFF, B34, DCP, FE9, GBV, LLT, MX0, SGC, UQA, WRS, 2LT
50 YEARS FROM NOW, DON'T YOU WANNA BE ABLE TO LOOK BACK AND SAY YOU HAD THE GUTS TO GET INTO THE CAR!?!?
ORDER STATUS : 6000 as of 08.18.2009. VIN# 33,985!!! His name is 'GOLIATH'!!!
GOT MY CAR!!!! AND I LOVE IT!!!!
JewelZ is offline   Reply With Quote
Old 07-13-2009, 01:44 PM   #8
alex33x
Crowley
Thanks it seems only the drivers side and center should dim.
LOL I guess your right, I just wanted to make sure I didnt have a defective engine, Iw ould hate to take my baby to the dealer for god knows how long to get warranty repairs done to it.
Old 12-15-2022, 02:11 AM   #9
GenesisCoupe
Drives: 2011 Chevy Camaro 2SS A/T
Question
It looks like to me that shaking at idle is not entirely correct. I have checked 2 cars with L99 engine from a rent-a-car and they doesn't have any shakings, that could be felt on the seats (that I have for a 2 years of ownership).
When I had 3.6 LFX, I also had shaking at idle, with random jerks without any ECM error or check engine light. I replaced the whole set of chains and the shaking went away.
Now I have a similar situation on my L99. The shaking intensifies if I agressively drive and then stop at a traffic light. I changed motor mounts but no result. Also checked with smoke generator for the air leakage and found nothing. In our local GM service they checked an oil pressure on the VVT and found great results (currenly use 5w40, 108K mileage).
Check engine light is not comes on, however, error P0011-00 constantly sits in the ignition system chapter in the ECM. Also in 8 cases of 10 I have "Service Stabilitrak" message that comes on during cranking then dissapear. To eliminate it I crank starter slightly longer that usual.
As I know, P0011-00 is related to the VVT sprocket and / or timing chain and / or camshaft position. Do you have any thoughts on this?
GenesisCoupe is offline   Reply With Quote
Old 12-15-2022, 08:06 AM   #10
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Talking
Holy thread resurrection...
Old 12-15-2022, 02:17 PM   #11
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Correct. Drivers and rear are the only dimming mirrors. The passenger does not.
FasNuf is offline   Reply With Quote
Old 12-15-2022, 10:37 PM   #12
bottletalk
Drives: 15 Camaro 2SS M6
July 2009, I don't have enough fingers to do the math on that one!
bottletalk is offline   Reply With Quote
Old 12-16-2022, 09:25 PM   #13
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Mine shakes for some reason to
Sorry wish I had your answer but couldn't resist
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 12-21-2022, 11:33 AM   #14
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
This is what solid motor mounts are for. No, not poly, solid
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
V6 engine idle showcamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 9 06-17-2009 05:03 PM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 07:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
