Old 10-07-2013, 08:00 PM   #1
berger6696
berger6696's Avatar
Drives: 97 Vette (sold), 13 SS 1LE
How do I drain my catchcan?
I bought the car used, has a Moroso catch can that does not have the little drain line on the underneath. It feels like a bolt. Is there an easy way to drain this?
berger6696 is offline   Reply With Quote
Old 10-07-2013, 08:07 PM   #2
berger6696
berger6696's Avatar
Old 10-07-2013, 08:23 PM   #3
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
Put a cup underneath and unscrew the Bolt.
gutterball is offline   Reply With Quote
Old 10-07-2013, 08:35 PM   #4
berger6696
berger6696's Avatar
I was afraid of that. Very little room underneath.
Old 10-07-2013, 09:17 PM   #5
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
I'm not familiar with the Moroso can, but if there is a drain bolt on the bottom you should be able to replace that with a brass drain petcock from a auto store. Then attach a hose to it and feed it down to the underside of your car. Then you can just put a cup under the hose and open the petcock to drain.
*You'd probably have to zip-tie the hose in a couple of places to keep it in place.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 10-07-2013, 11:57 PM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Nice engine and ride btw!
Mods:
Old 10-08-2013, 11:59 AM   #7
berger6696
berger6696's Avatar
Thanks. This is probably a stupid question, but is the catch can two pieces like the picture below? If so, shouldn't I be able to just unscrew the bottom half to empty it? There is absolutely no room for a cup under this thing. Thanks
Old 10-08-2013, 12:20 PM   #8
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
You should be able to loosen the screw on the mounting bracket, and slide the whole can up and out. Then unscrew the drain cap at the bottom to empty it.
Old 10-08-2013, 12:27 PM   #9
dkp2LT
dkp2LT's Avatar
Drives: '11 2SS, '11 C6 GS, '04 MDX
Tell you what. Based on your engine photo I can see the problem. My V6 catch can is much simpler so I think the easiest way to fix is if we trade cars.
dkp2LT is offline   Reply With Quote
Old 10-08-2013, 12:38 PM   #10
berger6696
berger6696's Avatar
Old 10-08-2013, 12:51 PM   #11
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
beautiful engine
JR 1 is offline   Reply With Quote
Old 10-08-2013, 02:14 PM   #12
berger6696
berger6696's Avatar
Well the good news is that there was very little oil in there. I put a towel underneath the can and unscrewed the bolt slowly. The car only has 1200 miles on it so I guess I kinda gambled that there wouldn't be much in there. There was only enough to fill the little plug screw. I will use slingshots suggestion next time. Thanks all!
Old 10-08-2013, 02:57 PM   #13
dkp2LT
dkp2LT's Avatar
I changed my oil for the first time after putting on a catch can. It's been around 12 months & ~1000 miles. I was really surprised what came out of there. Not in quantity but quality. May put one on my dd now.
