Old 10-08-2013, 07:51 PM   #1
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
GPI VVT Camshafts
I have been getting a lot of pms with questions about our cams, so I figure I'd post up some basic info on them.
VVT grinds:
SS1, Power range idle to 6500
SS2, Power range 2000 to 6700 (works with stock converter or 2800+ converter)
SS3 Power range 3000 to 6800+ (3200+ converter required)
SS4 Power range 4000 to 7000+ (3600 minimum converter, best with 4000+) (flycutting required)
All these cams can be altered for different specific setups and also for forced induction, and/or nitrous applications.
For cam selection, just message me with your setup and goals, what kind of idle you are looking for and we can go from there!
Rhino79 is offline   Reply With Quote
Old 10-08-2013, 08:11 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
Is there something between the SS3 and SS4???? No shop around me wants to fly cut my pistons :(. Anyways Ordering mine this Fall!!!!!!
62nalide is offline   Reply With Quote
Old 10-08-2013, 08:15 PM   #3
Rhino79
Rhino79's Avatar
Yes we can tailor one for u without cutting to work with ur converter.
Old 10-08-2013, 08:34 PM   #4
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
How much difference is there between the SS3 and SS4? Also where does your old Mast cam fall in comparison to these?
Camarojt is offline   Reply With Quote
Old 10-08-2013, 08:37 PM   #5
62nalide
62nalide's Avatar
Drives: 2013 SS
Good question!
Old 10-08-2013, 09:44 PM   #6
Rhino79
Rhino79's Avatar
The mast is slightly larger in duration than the 3. The 4 is very aggressive. Personally, the 3 may be lesser in duration than the mast ss but it will make more tq and rival it's hp.
Old 10-08-2013, 09:56 PM   #7
Camarojt
Camarojt's Avatar
Good info. Thx.
Old 10-08-2013, 11:52 PM   #8
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
What's mine? Lol
Ss3 or ss3.5?
-John S.
Old 10-09-2013, 07:25 AM   #9
Rhino79
Rhino79's Avatar
Yours would be the ss3.
Old 10-09-2013, 08:31 AM   #10
Denis
Denis's Avatar
Drives: 2010 SS
As far as idle goes, if you want a rough idle it would mean increasing duration correct? Or overlap? I forget. Does that have a negative effect anywhere else? Like are you sacrificing anything to get that lope?
I'd really like to start sourcing parts for a cam swap.
Old 10-09-2013, 09:03 AM   #11
Rhino79
Rhino79's Avatar
The lobe separation will change idle characteristics, and a tighter lsa (111 vs a 114) will lope more aggressively. But with that, overlap increases and drive-ability can decrease some on larger cam profiles. BUT, a lot of that falls on the hands of the person calibrating the car, as I have done several cammed ls setups, from 108 and up on lsa. You make a tight lsa drive good, but it is more work, and the rest of the setup needs to be right.
Obviously changing duration is going to have some effect as well but when someone is looking for a specific idle and or power range, it isn't going to just come down to one thing like lsa, or duration....its the profile as a whole.
Old 10-09-2013, 09:47 AM   #12
Denis
Denis's Avatar
Drives: 2010 SS
got ya, thanks for clearing that up. shot ya a PM
Old 10-12-2013, 08:58 PM   #13
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Got my order in for a turbo stock converter cam. Going to install and tune before building TT set-up.
Thanks Rhino!
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Unobtainium is offline   Reply With Quote
Old 11-26-2013, 05:40 PM   #14
jkof08
jkof08's Avatar
Drives: Black 2SS/RS
so what if i dont want a very lopy sound i like it clean, can i get a cam like that, but still produce good hp?
C.A.I. CAI, FlowMaster Pro Series, 1LE Strut Brace, Ported Throttle Body, Vengeance Tune, JRE Scoop, MSD Wires, 3.70 Gears, Stainless Works LT Headers and Hi Flow Cats, Pro Torque 3500 stall, LS3 Conversion Stage 2 TSP Port & Polished Heads, Kaotik CAM. 18x10 Forgestar F14 wrapped in 305/45/18 MT Street ET II's
12.068 @ 119.9 1.9 60ft (on 20' DR's with a VVT CAM)
jkof08 is offline   Reply With Quote
