Seeking 9s on M6...
Drives: 2012 2SS/RS LS3 aka "BlackWidow" Join Date: May 2012
ZL1 Diff fluid vs. SS Diff Fluid
I hate to start a thread on a topic that looks played out, but I couldn't find what I was looking for. I have a ZL1 diff in my SS and I use the recommended GM fluid with the friction modifier included.
I bought a used SS diff (auto) to install for the Texas mile (3.27 gears), and am in the process of swapping them. I drained the used SS diff and need to refill it. I have the GM ZL1 fluid. Will that work in the SS diff? I'm curious why the owners manual recommends fluid w/o friction modifier, but then you have to add the friction modifier .I talked to a guy at Chevy who started to say "no", the SS needs different amount of friction modifier (BTW, the SS fluid at the dealer w/o friction modifier is $35 a quart ), and then he changed his mind and said go ahead and use the ZL1 fluid.I'm thinking i'll just go buy some royal purple from the local auto parts store. Does anyone know what if anything is different w/the ZL1 diff fluid? vs. off the shelf royal purple, Mobile 1, redline? vs. GM/AC Delco $35 a quart fluid w/out friction modifier that you have to add friction modifier to???
Drives: Camaro 2SS/RS Join Date: Sep 2013
You will be fine with either and I would use the friction modifier if you have it and it are doing it anyways.
![]() Drives: 2011 LS3 Join Date: Jan 2012
You should be fine with royal purple or lucas. I used them both in my diff in my silverado and they work fine with all the towing ive done.
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
Seeking 9s on M6...
I went w/Royal Purple and seemed to do fine on 3 standing mile runs...maxed out at 189mph.
![]() Drives: 2012 2SS M6 Join Date: Nov 2013
