Old 10-09-2013, 03:28 PM   #1
was619
Billy The Kid
was619's Avatar
Drives: Cyber Grey 2SS/RS
Official 'cheep' drag wheel options (vette c5/c6 wheels)
I'm am starting this thread to breakdown a clear explanation of what corvette wheels will fit on the rear of our 5th gens, with or without spacers.
Please be aware this is not a thread about whether spacers are 'safe' or not please keep your personal opinions out of it.
No spacer needed:
18x9.5 stock c6z fronts will work, +40mm offset - typically more expensive wheel than the oher options
grand sport c6 18x9.5 fronts will also work, +40mm offset - different spacing than the 5th gen studs
Spacer needed, minimum size:
the C5Z 18x 10.5 (+58mm offset) will work with a 5mm spacer to achieve +53mm which will clear
C5Z 18.9.5 (+65mm offset) 12mm? to achieve 53mm?
The number you are aiming for is +53mm or less to safely clear the brembo calipers.
I hope this proves to be a good reference for someone.
As alway check the torque on your lugnuts when you get to the track to make sure they are secure, and recheck and tighten as needed for a little added peace of mind.
thank you in advance for your responses!
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension,
MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners
Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels
was619 is offline   Reply With Quote
Old 10-10-2013, 12:16 AM   #2
shiznight
Drives: 2010 camaro ss l99
5/16 spacer for these. I bought the spacers from pep boys for 10 a pop.
TSP vvt-1 cam, Headers-catless xpipe, Knn intake 417/422
Nitrous 100 wet shot 520/585
Racestar super 94 17x4.5/17x9.5
highest trap to date 120.6mph
12.0@spinfest. rage
shiznight is offline   Reply With Quote
Old 10-10-2013, 04:11 PM   #3
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
Drives: 2010 Camaro 2SS/RS/LS3/M6
Great Thread!
Texas Speed LT Headers with HF Cats, Borla ATAK Exhaust, MGW Short Throw Shifter, ADM CAI with Scoop, Elite Oil Catch Can, Mishimoto Aluminum Radiator, Pedders XA Coilovers, Mantic Twin 9000 Clutch, PFADT Solid Subframe Bushings, PFADT Front & Rear Sways, PFADT Upper Control Arm Bushing, PFADT Trailing Arms/Tie Rods, Whiteline Adjustable End Links, Whiteline Adjustable Lower Control Arms, Pedders Diff Bushings, Line Lock, ACC Side Markers, ACC Reverse Lights, Custom Tune from Nitrous Express.
Iroc2430 is offline   Reply With Quote
Old 10-10-2013, 08:33 PM   #4
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
just wanted to let everyone know that while the grand sport wheels will fit, they are not correct spacing as the camaro studs , they are off by 1mm, you are safe running them, but would re torque as a precaution between runs
mikepage0007 is offline   Reply With Quote
Old 10-11-2013, 12:49 AM   #5
was619
Billy The Kid
was619's Avatar
5/16ths is almost an 8mm spacer. can you give some details on the offset/size of the wheels you posted?
Originally Posted by Iroc2430 View Post
Great Thread!
Thank you!
Originally Posted by mikepage0007 View Post
just wanted to let everyone know that while the grand sport wheels will fit, they are not correct spacing as the camaro studs , they are off by 1mmyouare safe running them, but would re torque as a precaution between runs
I'd like to keep it updated with good info like this! Thanks!
Any additional info that can be added would be greatly appreciated!
Old 10-11-2013, 06:39 AM   #6
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
This is true of ALL Corvette wheels, not just the Grand Sports. The Corvette bolt pattern (and a good majority of previous GM cars) is 5 x 4.75 in., which converts to 5 x 120.65 mm. The 5th Gen Camaro is 5 x 120 mm. So, yes, there is a slight difference of 0.65 mm, and when you consider that measurement is taken between the center point of two studs, then each stud on the Corvette is a whole 0.325 mm further apart. Hardly worth mentioning. The bolt pattern will fit without issue, and there are even guys daily driving on these wheels. Personally, I would probably still consider running a hubcentric centering ring just to make sure.
I have a pair of 18x9.5" (+40) Corvette ZR1 replicas ready to install (no spacers needed)....just waiting on the funds for the tires!!! The wheels weigh 26 lbs. each. It's pretty bad when you can get (2) wheels cheaper than one tire!!!!!!!!!
blazzin1 is offline   Reply With Quote
Old 10-11-2013, 09:48 AM   #7
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
I have a pair of 18x9.5" (+40) Corvette ZR1 replicas ready to install (no spacers needed)....just waiting on the funds for the tires!!! It's pretty bad when you can get (2) wheels cheaper than one tire!!!!!!!!!
Where did you buy those? They are awesome!
Retro69 is offline   Reply With Quote
Old 10-11-2013, 09:54 AM   #8
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i run the 18x9.5 40 mm offset fronts on the rear with no spacer . i tried the 56 mm offset but u will need a 1" or so spacer . i have 1.5 spacer and u got plenty of room
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 10-11-2013, 10:41 PM   #9
blazzin1
blazzin1's Avatar
PM Sent
Old 10-12-2013, 11:32 AM   #10
was619
Billy The Kid
was619's Avatar
26 lbs... That is significant considering the stock 20s are 32 lbs. so that's a total of a 12lb reduction of rotational mass minus the difference in tire weight(if they are more/less than the pzeros.
It is just so hard for me to believe that we couldn't find a Cheeper 17inch options. The price difference for a 17 vs 18, for example on an M.T. E.T. Street is a little over $60 difference. And the ability to use bias ply 'slicks' in a 17 creates another issue.
Old 10-12-2013, 12:11 PM   #11
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
Anyone with links where to get these wheels/Spacers?
Just what i need for weekend racing takeoffs!
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 10-14-2013, 12:16 AM   #12
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
18x9.5 ZR1 wheels front and back, 305/45R18 NT05R's on back, 265/ R18 Nitto's up front. Some mods necessary to fit front wheels.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 03-24-2014, 08:52 PM   #13
Denis
Denis's Avatar
Drives: 2010 SS
Little bit of back from the dead action lol
for you guys actually running these, are you running hub centric rings or just bolting them up and going?
Old 03-25-2014, 10:41 AM   #14
Pro Stock John
Writer
My ZR1 replicas do not have hub centric rings and I've never had a problem with them.
PROJECT HEAVY CHEVY
