View Poll Results: How much difference on dipstck when you wait vs no wait for oil to settle down?
No difference 4 25.00%
0 to 1/4 quart difference 3 18.75%
1/4 to 1/2 quart difference 3 18.75%
1/2 to 3/4 quart difference 4 25.00%
3/4 to full quart difference 0 0%
over a quart difference 2 12.50%
Voters: 16. You may not vote on this poll
Old 10-09-2013, 09:49 PM   #1
NoItsOnlyAV6_ButItRocks
Drives: 2010 2LT RS M6 IOM FlwMstr
Oil on dipstick..Measurement variance
The Camaro owners manual says to "...give the oil several minutes to drain back into the oil pan. If this is not done, the oil dipstick might not show the actual level...."
How much variation have you seen when taking a measurement of oil on your dipstick?
For example, if you take a measurement after the car has sat "...several minutes..." may get a full reading (no oil loss) on your dipstick. However, after a bit of driving for 10 or more minutes and checking it immediately without giving "...the oil several minutes to drain back into the oil pan..." the dipstick may measure that you are half a quart down.
I ask because I went into Jiffy Lube and received instant service and they noted on my receipt that there was no oil on my dipstick but I had measured a full dipstick an hour before. See this link for the full fiasco: http://www.camaro5.com/forums/showthread.php?t=319431
NoItsOnlyAV6_ButItRocks is offline   Reply With Quote
Old 10-10-2013, 03:03 PM   #2
OK I placed my vote. Anyone else?
Old 10-10-2013, 03:21 PM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
When I had my LLT, the oil was a bit lower if you did not let it settle a bit, but there was still clearly plenty of oil on the stick. I doubt it would have event amounted to 1/4qt less.
FSP tuned: 377/389
Old 10-10-2013, 10:26 PM   #4
Thanks for voting!
Old 10-10-2013, 11:10 PM   #5
RubyCamaro
Jan
RubyCamaro's Avatar
I never really checked it before it settles since you are supposed to wait so??????????
Old 10-11-2013, 02:38 AM   #6
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
on the ss it usually takes about 30 seconds of idle time right after you change the oil . on mine its about half way on the hash marks and it take another 1/2 quart to top it off
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
jonathanmoguel is offline   Reply With Quote
Old 10-11-2013, 06:56 AM   #7
Yes that sounds right for when you are filling up. It might end up being the same number.
In this poll, it is going the other way. For example, once you have the oil filled and then then go driving around for several minutes and then take another measurement as soon as you stop. You might find that it is down a certain amount (e.g. 1/4, 1/2, 3/4 of a quart) but then without adding anymore you wait several minutes and then it returns back to full.
Old 10-12-2013, 10:40 AM   #8
mailclerk
Drives: 2013 Camaro 2LT/RS
No matter what my vote is I always measure my oil by allowing the motor to sit for at least 30 minutes! That's why I measure first thing in the morning before turning my engine over. When you measure make sure your on level ground (resaonable).
Mail Clerk
mailclerk is offline   Reply With Quote
