Old 10-12-2013, 11:29 AM   #1
davidbjcu
Drives: 2012 Turbo 45th 2SS
HELP me with my sh*tty 60' times
I have a 45th L99 that just doesnt launch. T76 front turbo, cam, exhaust and 18" MT DRs. 530rwhp. Consistently pulls 2.0-2.1 60' times. Im holding down the brake and giving gas until the tires borderline spin (1500-1600 rpm). Any advice??! Im running high 11s-12.00 1/4 mile.
davidbjcu is offline   Reply With Quote
Old 10-12-2013, 11:45 AM   #2
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Try 1000 to 1200 RPM on launch. And tires at 18 PSI.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 10-12-2013, 11:50 AM   #3
white ZL1
Drives: none
Sounds like you need more converter.
white ZL1 is offline   Reply With Quote
Old 10-12-2013, 12:20 PM   #4
GMteSSted
GMteSSted's Avatar
Drives: 2018 ZL1 1LE
I am similar in power and with the stock converter I average 1.70 - 1.75 60' on less desirable tires, Nitto 20" 555r's. I drop the tire pressure to 18lb, turn off all nannies, launch from idle, and quickly ease into the throttle to avoid tire spin. I don't smash the throttle on launch. I also really heat the tires on burn out. The Nittos stick better with lots of heat. With the M/T's you should be getting better traction.
I do have a Maggie that gives me instant boost. The turbo has to be spooled up on launch to help the 60'. You may not be getting into your boosted power band fast enough with the turbo to help your 60'?
GMteSSted is offline   Reply With Quote
Old 10-12-2013, 01:30 PM   #5
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Post a video of your run that way we can see how you do your burnout. Could be you aren't getting the tires hot enough. Could be your in the water box too far slinging water in your fender wells.
Run 16 lbs of air in them.
Camarojt is offline   Reply With Quote
Old 10-12-2013, 01:47 PM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
What type of turbo? My Magnum 76mm spooled very quickly and I was seeing 1.80 60ft with my stock converter on a Denali truck that was on slicks. What tires are you running?
62nalide is offline   Reply With Quote
Old 10-12-2013, 06:05 PM   #7
davidbjcu
Ill try launching from an idle or less rpm. I am spinning a bit but I guess I was hoping the MTs would stick. I definitely am planning on a new converter next spring.
Old 10-12-2013, 06:23 PM   #8
Mr. Nasty
Mr. Nasty's Avatar
What psi are you running in them? And are you doing a good burnout? I found the sweet spot at 18 psi with the MT my 60' in 1.70s and lower.
Old 10-12-2013, 07:46 PM   #9
davidbjcu
8 lbs of boost. im running about 18 psi. I do a good burnout. (although I am considering a line lock). Nannies off. Are you guys all launching off idle? I guess im just surprised the mts dont hook with a stock converter. That or I just suck at driving lol
Old 10-12-2013, 08:41 PM   #10
Mr. Nasty
Mr. Nasty's Avatar
Just above 1000 where ever thing tight.
Old 10-12-2013, 08:58 PM   #11
Camarojt
Camarojt's Avatar
My car launches best off idle. But my car is a bolt on only car. MT with a 3600 Circle D and I cut 1.56 60ft.
I was having spinning issues last time at the track, but I've just about identified it being all burnout related.
I would cut back to back 1.56's then all of a sudden a 1.75-1.85. And trust me, a 1.85 feels like shit when u have been cutting 1.56.
So I'm learning exactly what my car needs to hit that 1.56 consistently. I can tell after my burnout if I'm gonna hook.
