Old 10-13-2013, 08:41 AM   #1
NoItsOnlyAV6_ButItRocks
Drives: 2010 2LT RS M6 IOM FlwMstr
40 causes of "Too Much" Oil Consumption
I came across this very interesting PDF that was published in 2004 by Amsoil as a Tech Bulletin. It has 40 reasons an engine can consume "Too Much" oil. Each of the reasons has a paragraph that explains the how and why to the reason. Seven pages long. Good Reading. I am now much wiser after reading it.
http://www.amsoil.com/techservicesbu...onsumption.pdf
Here are the 40 reasons as listed in the table of contents:
1. External Oil Leaks
2. Front or Rear Main Bearing Seals
3. Worn or Damaged Main Bearings
4. Worn or Damaged Connecting Rod Bearings
5. Worn or Damaged Camshaft Bearings
6. Worn Crankshaft Journals
7. Tapered and Out-of-Round Cylinders
8. Distorted Cylinders
9. Clogged “PCV” Valve
10. Honing Abrasive
11. Worn Ring Grooves
12. Cracked or Broken Ring Lands
13. Worn Valve Stems and Guides
14. Bent or Misaligned Connecting Rods
15. Worn or Improperly Fitted Wrist Pins or the Wrong Pins
16. Wrist Pins Fitted Too Tightly
17. Clogged Oil Passages
18. Unequal Tightening of Main Bearing Bolts or Connecting Rod Bolts
19. Unequal Tightening of Cylinder Head Bolts
20. Dirty Cooling System
21. Dirty Oil
22. Too Much Oil in Crankcase
23. Incorrect Piston Rings for Type of Engine or Type of Service
24. High Engine Vacuum
25. Worn Timing Gears or Chain
26. Piston Rings Fitted with Too Little End Clearance
27. Worn or Broken Piston Rings
28. Piston Rings Stuck in Grooves
29. Late Valve Timing
30. Oil Pressure Too High
31. Oil Viscosity
32. Piston Slap
33. Internal Gasket/Intake Breach
34. Spark Knock
35. Aftermarket Performance Chips and Modifications
36. Lugging Engine
37. Inappropriate Operation of Overdrive
38. Leaking Turbocharger Seal
39. Restricted Air Intake
40. Fuel Dilution
NoItsOnlyAV6_ButItRocks is offline   Reply With Quote
Old 10-13-2013, 08:58 AM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
There are more than a few of those I would never have thought of.
Sent from my DROID RAZR HD using Tapatalk
Firefighter is offline   Reply With Quote
Old 10-13-2013, 12:06 PM   #3
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
How about #41, best friend's dad forgot to reinstall the oil drain plug after draining out old oil?
I stopped by to see a big note taped to steering wheel: Do NOT Drive. No Oil!
I asked him what happened and he said "Five quarts in, five quarts out, ya know what what I mean, John?" 30 years later we still get a laugh out of that one. He said the worst part was that his wife saw it happen and never let him forget it.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-13-2013, 12:15 PM   #4
Old 10-13-2013, 12:29 PM   #5
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
So with this list, pretty much any and everything will cause oil consumption. I hope we never have to go back to the day when we carried a quart of oil in the trunk.
I had a Harley back in the 70's that the owners manual said normal oil consumption was a quart every 700 miles.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 10-13-2013, 04:29 PM   #6
Originally Posted by patternpilot View Post
...I had a Harley back in the 70's that the owners manual said normal oil consumption was a quart every 700 miles.
A guy once told asked me: "Did you know why Harley's last for decades?"..."It's because they can't hold oil... You constantly have to keep adding it. It assures everything is always well lubricated. It's like a constant fresh oil change."
Old 10-14-2013, 01:13 AM   #7
JohnnyBfromPeoria
I've owned a couple of vehicles over the years that fit this description. Never a Harley, though, even though I've ridden for 36 years and owned seven bikes. Just never felt like waiting for parts to come in so I could go for a ride.
I kid, I kid.
John B.
low oil, oil consumption, too much oil
