![]() Drives: Black 2SS/RS Join Date: Mar 2013
12.843 and i got beat by a stock 5.0
ok so i have the below mods in the sig and i raced a stock 2013 mustang 5.0, he beat me, i want to know what my issue was. i had a quicker 60 ft, 330ft and 1/8th, then he had a quicker 1000ft and 1/4 mile. why is this, shouldnt i pull in the top end bc of my mods? this makes me wonder should i have the engine cleaned out and add a catch can or is it something else? it was tuned by jannetty. any help would be appriciated Im number 17 on the left.
C.A.I. CAI, FlowMaster Pro Series, 1LE Strut Brace, Ported Throttle Body, Vengeance Tune, JRE Scoop, MSD Wires, 3.70 Gears, Stainless Works LT Headers and Hi Flow Cats, Pro Torque 3500 stall, LS3 Conversion Stage 2 TSP Port & Polished Heads, Kaotik CAM. 18x10 Forgestar F14 wrapped in 305/45/18 MT Street ET II's
12.068 @ 119.9 1.9 60ft (on 20' DR's with a VVT CAM) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Well he did leave the line before you did and he was already a 1/2mph faster than you in the 1/8th so you wasn't going to catch him. My GXP had about the same mods and I ran 12.80 so are about right. The new 5.0s are no joke. They make great power and are 400+lbs lighter.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
Lining Up!
I thought you should have had him too, my 11 ls3 m6 with only longtubes and no cats will out pull my buddys new 5.0 m6
11 Camaro 1SS - Summit White - Black Stripes - 6.2 - M6 - Hurst Short Throw Shifter - Sun Roof - Rally Sport - Dynatech LT - ORY - Night Fury Cam - 1LE Sway Bars -
damn...close race though
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 GT350 Join Date: Jan 2011
Nothing at all surprising about his e/t or mph. A properly driven and launched 5.0 should be capable of 12:70s-12:80s. I don't think you did anything wrong it's just the 5.0 is a more efficient 1/4 mile car than the SS in most races. When I had my SS I had similar mods to yours (LS3) I got tired of being beaten by stock 5.0s as well. I upped my game and went for a cam, LT, DRs setup. The problem I had then was that lightly modded (tuned & DRs) 5.0s were still beating me.
What tires were you running, did you try to adjust launch rpm, it seems with a 3500 stall you should have a better 60'
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
#6 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
How was your launch? I still feel you could have done better (not knowing track conditions). Stall, gears, tune, intake, headers on ur car can get a quicker time than that.
I pulled a 12.91 (109 trap speed 1.96 60ft) with just headers, intake, and tune, in humid, wet, and very hot track conditions, and not a perfect launch too. Stock tires, L99. You adding gears and a stall, and cooler temps this time of the year, should give you more than a .06th of a second. Your car is capable of better times, based on what I did with mine alone. I would think my trap speed being the same or higher than yours, means you should have been pulling more top end, might be something in your tune, or like you said, somethings dirty. |
#7 |
[COTW 5/12/14]
RT doesnt effect ET, unless im mistaken.
#8 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
These new 5.0s are no slouch and if not running at perfect conditions they will take you more often than not
#9 |
21' inch wheel option street tires 285's in the back 255's in the front launching at 1900 any harder gets wheel spin. The track was well preped for a private event do it was sticky I had glue on my tires in the pits
#10 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
The 21"s are the issue then. Everything else checks out.
#11 | |
[COTW 5/12/14]
Right
Sounds like traction isnt a problem, especially since you were able to launch at 1900 with street tires with that stall. 21's are bad news, and will hurt your 60'. I still think you could have done better, but 20's vs 21's in this race could have let you edge him out and get the win. |
#12 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Something isint right, my L99 full boltons, vararam, kooks 1 7/8's, 3" catless Flowmaster cat back and stock converter made 12.7's on stock pirellis. I'd say yea ditch the 21's as well.
#13 |
It doesn't effect ET's but he did leave on him, therefore, he would have beat him.
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: P1X ProCharger, Squash dual fuel pumps, ID fuel injectors, Cam: Pat G designed/EPS Ground (228/234 .629”/.629” 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8” Long Tube Headers, Dynomax Bullet Cat-Back System, Skip Shift Eliminator |
#14 | |
[COTW 5/12/14]
