Old 10-15-2013, 03:48 PM   #1
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
Tin vibration noise at approx 45 mph
I have a 2012 LFX V6 RS. Shortly after installing axle back exhaust there seems to be a bit of a tin vibration noise at about 45 mph but everything on the axle back is solid tight. Was wondering if it might be a heat shield getting caught by the airflow under the car. I plan to check underneath when I dothe next oil change. Anyone have a similar issue?
Lacpac is offline   Reply With Quote
Old 10-16-2013, 09:36 AM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
No tin sound....
I have a small bit of drone around the 2000-2200 RPM range...
Mods:
Old 10-16-2013, 09:45 AM   #3
Lacpac
Lacpac's Avatar
Thanks Kaboom, yea I get a little drone noise at 65-70 but this is a different spuratic sounding noice like a rattling heat shield and it only happens around 40-45.
Old 10-28-2013, 10:13 PM   #4
Uhile3
Uhile3's Avatar
Drives: 2012 V6 Camaro and 2004 Gto
Have the same problem, but it also makes noise on first startup of the day.
Uhile3 is offline   Reply With Quote
