Old 10-16-2013, 10:27 PM   #1
Msmall143
Msmall143's Avatar
Drives: Camaro
Adding subwoofers to 2013 ss with my link
Hey guys,
I've looked on here a bit and haven't seen anything specific as to what I need to upgrade my system on a 2013 ss. I've seen lots on the 2010-12's but given that the 2013's changed a bit with my link I just don't know what I need.
I'd like to add a sub or 2 but want to do it the right way. Any advise would be appreciated, even if its a link to a thread. But please be specific to the 2013's
I also welcome Pam's or responses from forum sponsors.
So what and how have you upgrades your 13's with my link?
Msmall143 is offline   Reply With Quote
Old 10-17-2013, 12:06 AM   #2
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
See if the sub thump harness supports 2013. If it does, just get that harness. Works well for me.
45thCamaro is offline   Reply With Quote
Old 10-17-2013, 02:55 AM   #3
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
Just get a high power line out converter and wire it into the amp on the drivers side trunk, I used the rear speaker outputs and then tapped the factory remote for my remote wire. I suggest investing in a good Line Out Converter though you will notice a difference. I used the Audiocontrol LC2i, it works great.
Im running 1 Cerwin Vega 10 in a 1.2 cubic foot slot ported enclosure and a JBL Amp. Im only pushing 175 watts RMS and it sounds awesome cause how small the cabin is.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 10-17-2013, 02:58 AM   #4
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
If you are plan on adding just the sub the franks harnes will be fine
lfree11012 is offline   Reply With Quote
Old 10-17-2013, 07:12 AM   #5
Msmall143
Msmall143's Avatar
Drives: Camaro
That's why I posted this....to see if anyone had used it on a 13
Old 10-17-2013, 07:14 AM   #6
Msmall143
Msmall143's Avatar
Drives: Camaro
Where are you guys adding te remote?
Old 10-17-2013, 07:58 AM   #7
45thCamaro
45thCamaro's Avatar
Hopefully someone will chime in, but as long as they didn't change the amp on the 13's it should work
Maybe find out the part numbers for both a 12 amp and a 13 amp. It works in my 12.
Old 10-17-2013, 11:11 AM   #8
Evotion
Warehouse 13 Survivor!!!!
Drives: '13 ZL1 - 69' Camaro
Just did a few weeks ago on my '13. Same amp, no issues. Works fine.
Evotion is offline   Reply With Quote
Old 10-17-2013, 12:39 PM   #9
Lord Ryan
Lord Ryan's Avatar
Drives: Chevy Prelude RS V4 Hot Pink Ed.
http://www.camaro5.com/forums/showthread.php?t=315902
******** T harness. Worked a lot better than the in line converter. 13 2lt rs with mylink. You need a mono amp for the sub, the factory amp is weak!
http://********.com/Chevrolet-GMC-Su...t-Product.html
A lot of members recommended calling Steve from ********. He'll tell you exactly what you need. Seems to be trustworthy.
Multiple coated Plasti-dipped rims. Double dipped blacked out Bowtie. Quad low quality plastic flat black tail light bezels. Super charged vanilla air freshner. DIY sound system.
Lord Ryan is offline   Reply With Quote
Old 10-17-2013, 12:50 PM   #10
Lord Ryan
Lord Ryan's Avatar
Also see http://www.camaro5.com/forums/showthread.php?t=316200
Old 10-17-2013, 07:16 PM   #11
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
The harness still works. The amp/wiring didn't change.
There are many of us using it, myself included. You can get the whole kit from ******** or piece it together yourself.
JimE is offline   Reply With Quote
