Old 10-17-2013, 11:08 PM   #1
raptor5244
Drives: 2022 CT4-V Blackwing
Unique things about the Camaro
Here are some things I noticed about the Camaro that I have not seen in many other cars. These are not bad, just not typical of other cars I have owned. Anyone notice any others?
1. Battery located in the trunk. Sure stays clean this way.
2. Emergency brake located on the passenger side of the center console.
3. Trunk release button located in the middle of the drivers side door panel.
4. Gas cap located on passenger side.
5. Ignition. You don't have to hold the key to start the car. You just turn it enough and let go and it continues to crank until it starts. Kinda like a push button start but using a key.
6. My 1le has 4 tires of the same size but none of them can be rotated. Rim size is different between front and back.
raptor5244 is offline   Reply With Quote
Old 10-17-2013, 11:35 PM   #2
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
Didn't know you couldn't rotate your tires. Different wheel sizes?
Also I have noticed the battery and wondered about it.
The trunk release didn't phase me to much.
I have wondered the same thing about the e-brake being on the passenger side!
I drove to the wrong side of the gas pump twice before I got used to it(yes I now know my car has an arrow pointing to the correct side, don't judge me)
One thing that cracked me up to is that our trunks have a anti kidnapped mechanism on the inside that you can pull and it will release the trunk from the inside. It has a man getting up and running out picture on it haha!
13lstuner is offline   Reply With Quote
Old 10-18-2013, 12:23 AM   #3
midnighter
Drives: nothing
7. Looks the better.
Old 10-18-2013, 12:52 AM   #4
oklapike
oklapike's Avatar
Drives: 2012 45th Anniversary SS Coupe
I could be wrong, but I think a lot of RWD vehicles have the battery in the trunk, supposed to help with weight distribution. Personally, I like having the gas on the passenger side, there's usually no wait at the gas station for me.
You should still be able to have your tires rotated side to side.
EDIT: My bad, I didn't know the 1LE tires were directional. The non-1LE SS tires can go side to side.
oklapike is offline   Reply With Quote
Old 10-18-2013, 01:08 AM   #5
TJR1952
TJR1952's Avatar
Drives: 2013 2LT
You will get longer battery life with it in a cooler place then the engine compartment.
TJR1952 is offline   Reply With Quote
Old 10-18-2013, 03:09 AM   #6
DefianceDan
VroomVroom
DefianceDan's Avatar
Drives: 2017 50th 2SS
I thought that the purpose of putting the battery in the trunk was so that On$tar would work in the event of a front end collision. (I think the computer for it is in the trunk as well)
2017 H50 2SS MX8 F55 NPP CF5 RN2
DefianceDan is offline   Reply With Quote
Old 10-18-2013, 03:30 AM   #7
Grimlock
dey see me rollin
Grimlock's Avatar
Drives: the magic school bus
But then wouldn't all GM vehicles have the battery in the trunk?
The HUD is nice and gets cool points from everyone who notices it.
Grimlock is offline   Reply With Quote
Old 10-18-2013, 04:45 AM   #8
Trunz150
Drives: 2014 2SS/RS Drop Top
No tier rotation? I am confused
Trunz150 is offline   Reply With Quote
Old 10-18-2013, 05:11 AM   #9
BlaqWhole
Drives: 2017 Camaro ZL1 A10
The SS has staggered wheels. So we have one size in the front and a different size in the back. If you use directional tires, then you won't even be able to rotate them to the other side of the vehicle. Camaro models that don't have staggered wheels can and should rotate.
BlaqWhole is offline   Reply With Quote
Old 10-18-2013, 05:56 AM   #10
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
The battery is in the trunk for better weight distribution, same reason the hood is aluminum.
MMC is offline   Reply With Quote
Old 10-18-2013, 06:53 AM   #11
suplex
suplex's Avatar
Drives: 2011 Coupe, 1LT, A6, No RS Package.
I had no idea about this one, I will have to give it a try.
Never Underestimate The Power of Forums
suplex is offline   Reply With Quote
Old 10-18-2013, 07:02 AM   #12
wayne watson
wayne watson's Avatar
Drives: 2014 camaro ss ,1967 chevelle ss,
Also in front end collision battery could explode or at least that's why they're in the back of my drag car plus no room for that ugly thing under hood. I've heard some cars are in fender well .much better in trunk
wayne watson is offline   Reply With Quote
Old 10-18-2013, 07:20 AM   #13
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
The battery is in the trunk because there's no room for it under the hood.The starter turning after the prompt from the key is part of the remote start feature even though remote start isn't an option on the manual trans.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 10-18-2013, 08:18 AM   #14
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
However, when you drive your wife's Camry, you still need to hold the key until it kicks over. Being used to the "turn and release" with the Camaro results in you looking dumb when you do it in other vehicles out of habit.
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
