Old 10-17-2013, 11:29 PM   #1
wutshotDJroomba
wutshotDJroomba's Avatar
Drives: 2012 Camaro LS/SC
Considering the IPS twin turbo
I have the most base model 2012 V6 offered and it has only the basic bolt ons, ported throttle body, Roto-fab CAI, SLP Loudmouth axle-back... Since I'm going turbo soon, is there anything else I would need outside of what comes included in the basic kit itself? Or will it just bolt-on and run with the tune normally? Anyone else install this one on a 2012 V6 yet, results?
"....Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot, it becomes the teapot. Now, water can flow or it can crash. Be water, my friend.”
-Bruce Lee
wutshotDJroomba is offline   Reply With Quote
Old 10-18-2013, 01:38 AM   #2
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
There's welding involved...at least. Not quite as simple as, say, the IPF S/C install.
Are the turbos both coolant and oil fed? Even my engine from a 1988 Mitsubishi Starion that I dropped into my 1987 Dodge Raider is both. I get the impression that these are only oil fed/returned, but I don't really know.
John B.
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-19-2013, 07:11 PM   #3
wutshotDJroomba
[quote=JohnnyBfromPeoria] There's welding involved...at least. Not quite as simple as, say, the IPF S/C install.
are you running the ipf s/c?
Posted from Camaro5.com App for Android
-Bruce Lee
Old 11-06-2013, 11:53 AM   #4
RS Speedriver
RS Speedriver's Avatar
Drives: 2018 camaro 1ss 1LE
I am planning on doing twins on my v6. but before that I am doing posi and gear swap.
RS Speedriver is offline   Reply With Quote
Old 11-06-2013, 11:57 AM   #5
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
I'd do the twins first. If you do gears first, they may be too much when u do the twins aftet
Old 11-06-2013, 01:46 PM   #6
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
So far I am inclining to do a S/C because the tuning and the hassle for it to be oil and water cooled and if the turbo messes up you won't be able to drive. If the S/C fails you are still able to drive it.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 11-06-2013, 03:20 PM   #7
RS Speedriver
yea but the twins are designed for a stock ratio are they not. cuz I am putting on 3.91s on
Old 11-06-2013, 05:04 PM   #8
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
I thought about putting 3.45 gears in (well full rear cradle swap) I think the biggest I would attempt would be 3.73.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 11-06-2013, 06:47 PM   #9
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
I don't think so but I may be wrong soon as my painter get his behind in gear and finish. Putting 3.91 in mine the problem is not the gears but the traction may be a issue.
Sent from my iPad2 on space mountain
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 11-06-2013, 08:18 PM   #10
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Quit whining you already know the answer for that problem. Put a longer swingarm on it. LOL Give me power I'll find a way to make it hook.
etmx183 is offline   Reply With Quote
Old 11-07-2013, 12:52 AM   #11
RS Speedriver
lol here we go.
Old 11-07-2013, 03:20 PM   #12
hunterv6
Always bet on Black
hunterv6's Avatar
Lmao, if I could I would.
Old 11-07-2013, 06:28 PM   #13
seanurban
Drives: 2016 2SSRS Black
I go back and forth on this. It looks like the IPS system puts out some serious power!
seanurban is offline   Reply With Quote
Old 11-16-2013, 05:47 PM   #14
RS Speedriver
so I did some thinking. and I am going with ss gear swap first before turbos. I want a build rear end if I am plannng to turbo it later
