Old 10-17-2013, 11:06 PM   #1
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
Smile Thoughts on hex vents
Considering on getting these. But I have a few questions. Has anyone DIY'd these? If so how was it? Also should these come before a vmax throttle body, and mrt v2 exhaust upgrade buying everything brand new? If I get a used deal on any of these of course I will snatch them up
Also how are the vents. Do they cool very well? And how many of you run them with the splash trays off in the rain? And how many run them with the trays on all of the time?
13lstuner is offline   Reply With Quote
Old 10-18-2013, 12:08 AM   #2
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
Hey - haven't done it myself but here is the link for the install video. Doesn't look too bad but would be nervous about cutting into my hood like this
http://youtu.be/ngmYBuQMu5c
RolltideSS is offline   Reply With Quote
Old 10-18-2013, 12:25 AM   #3
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
The you tube video and instructions they come with will tell you everything you need to know to confidently(Loose term seeing you are cutting into a perfectly good hood) install these yourself. Make sure you have the right tools and you are good to go.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 10-18-2013, 07:35 AM   #4
13lstuner
13lstuner's Avatar
How do you like your throttle body?
Old 10-18-2013, 07:40 AM   #5
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
If you can wait, have them done at the Fest in May. Maybe someone could chime in the vendor that has been at Indy the last two years. I would think he will be there again as he was one busy SOB all weekend!
its a syn is offline   Reply With Quote
Old 10-18-2013, 08:01 AM   #6
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
The HexVents are great! I had mine done at the Fest and got to help with the install. It is very straight forward. The install is very straightforward. I really like mine. Good luck with them.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 10-18-2013, 08:51 AM   #7
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
It's good. Quicker throttle response. That really is about it. Helps for downshifting blipping the throttle.
Old 10-18-2013, 09:04 AM   #8
Denis
Denis's Avatar
Drives: 2010 SS
Originally Posted by bluebeastsrt View Post
Measure twice, Cut once. Good luck.
HAHA i said the same thing when i installed my TL1 hood insert. ended up measuring like 6 times! haha
but right before i took the cutting wheel to it i had some SERIOUS second thoughts. but it all works out in the end.
i know its not the same as the Hex vents but the idea of cutting your hood is still there. so measure as many times as you feel is necessary because you only get once shot to cut it.
Old 10-18-2013, 09:07 AM   #9
2012REDSS
Drives: 2012 Camaro SS
yea its one of those projects the beer is best saved for after the cutting is done but its not bad and they work great
2012REDSS is offline   Reply With Quote
Old 10-18-2013, 09:12 AM   #10
ssmike
BL1ZZRD
ssmike's Avatar
No DIY needed! The video and instructions are spot on and very clear! It made the decision to drill and cut a lot easier for me!
Old 10-18-2013, 09:16 AM   #11
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
It's easier to measure and cut one big hole than it is it cut two smaller ones and get them exactly even and the same size...
The Bird is the word!
Old 10-18-2013, 09:53 AM   #12
13lstuner
13lstuner's Avatar
What did yours end up looking like? And what are the function of yours besides engine cooling?
Old 10-18-2013, 09:54 AM   #13
13lstuner
13lstuner's Avatar
I slightly agree. I think the thing that would make them harder is getting them perfectly lined up with the cowl line.
Old 10-18-2013, 09:56 AM   #14
13lstuner
13lstuner's Avatar
Hmmm I've been considering that for my next mod.
2ls, hex, mrt v2, vents, vmax
