Old 10-19-2013, 08:49 PM   #1
Nemax
Nemax's Avatar
Drives: 2012 Camaro 1LT/RS
Quad tips on Stock exhaust
Is there any way to install quad exhaust tips on stock v6 muffler?
I bought these tips: http://tips.byethost4.com/dualindividual.html
Need to keep the stock muffler because my car is getting exported to EU and they are really strict on noise. Also i bought and installed the 1LE diffuser.
Appreciate any input thanks.
Nemax is offline   Reply With Quote
Old 10-20-2013, 11:22 AM   #2
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
If you're planning to do this by yourself you'll need a reciprocating saw (sawzall henceforth) and welding equipment. This would pretty much install like an axle back exhaust kit: saw off what you're replacing and bolt/weld on the new. When I sawed my mufflers off I found it helpful to cut a sawzall blade with the sawzall so that it would fit easier in the small work space. Basically I cut a blade shorter and gave it a sharper angle.
6bangerBOOM is offline   Reply With Quote
