![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
LFX fuel pressure
Having trouble locating the info. Anyone know what the fuel pressure is for the LFX engines.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
Fuel pressure
Ignition ON, engine OFF ............................... 345-650 kPa (50-94 psi) Relieve the fuel pressure to 69 kPa (10 psi). Verify that the fuel pressure does not decrease more than 14 kPa (2 psi) in 5 min. |
![]() 1 - T8E Ignition Coil 5 2 - Q17C Fuel Injector 3 3 - Q17D Fuel Injector 4 4 - Q17E Fuel Injector 5 5 - Q17F Fuel Injector 6 6 - T8F Ignition Coil 6 7 - T8D Ignition Coil 4 8 - T8B Ignition Coil 2 9 - Q17B Fuel Injector 2 10 - B47B Fuel Rail Pressure Sensor 11 - Q17A Fuel Injector 1 12 - T8A Ignition Coil 1 13 - T8C Ignition Coil 3 |
![]() 1 - Q38 Throttle Body 2 - B23D Camshaft Position Sensor - Bank 2 Intake 3 - B23C Camshaft Position Sensor - Bank 2 Exhaust 4 - T8B Ignition Coil 2 5 - T8D Ignition Coil 4 6 - T8F Ignition Coil 6 7 - B37B Engine Oil Pressure Sensor 8 - G18 High Pressure Fuel Pump 9 - B34 Engine Coolant Temperature Sensor 10 - M64 Starter Motor 11 - B68B Knock Sensor 2 12 - Q2 A/C Compressor Clutch 13 - Q6C Camshaft Position Actuator Solenoid Valve - Bank 2 Exhaust 14 - Q6B Camshaft Position Actuator Solenoid Valve - Bank 2 Intake |
Under Rear of Vehicle Components
![]() 1 - A6C Fuel Pump and Level Sensor Assembly - Primary 2 - B150 Fuel Tank Pressure Sensor 3 - A6D Fuel Pump and Level Sensor Assembly - Secondary 4 - B47 Fuel Pressure Sensor |
#6 |
Thanks for the info....wanting to test a few things when i get my car back as its in the shop again still dealing with the rear. I had the shop pull the rear out again as its whining so i want them to reshim it. Now they noticed one of the NEW carrier bearings prematurely failed, so i had to order one. Hope to get the car back later today. Frustrated...got $3500 into this rear now..could of bought a Moser for the money i have in this one.
#7 | |
Drives: 2011 2SS Whipplecharged LS3 Join Date: Aug 2015
Unfortunately this doesn't help unless you are subscribed to alldata. Any chance you can do some screen grabs and reshare? |
#8 |
![]() ![]() ![]() ![]() ![]() Drives: Never just fly under the radar Join Date: Jul 2015
etmx183 hasn't been active for 1 1/2 years and thread is almost 7 years old. Might have better luck starting a new one with your question.
Old Skool |
