![]() Drives: 2010 Camaro ABM 2SS/RS Join Date: Jun 2013
2010 - Any Known Issues?
I am getting close to pulling the trigger on a used Camaro. The last thing concerning me about a 2010 is the fact that it is the first model year of the new platform. Are there any significant issues with the 2010 model year that I should be aware of? I'm trying to decide between a 2010 ABM and a 2011 or 2012 Crystal Red Jewel Tintcoat. I prefer ABM, but am a bit nervous about the 2010. I'm sure this has been covered in other threads, but I wanted to throw it out there.
I have a 2010 with about 55k on on the clock and I haven't had a single issue.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
I looked at 10's but wound up in an 11 because I wanted the HUD. Glad I made that choice
2011 2SS/RS built 8/24/10
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Early VIN number '10s have problems with weak output shaft on the manual trannys. That all I can think of right now...
2010 Camaro SS LS3 - No Modz
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
The 2010 is actually Red Jewel Metallic, lol...and it was probably the most awesome color ever produced. As far as the car, I've had nothing crazy happen and mine is a 2010 that had about 10,700 miles on her when I got it. I think they put stronger axles in the 2010 after a certain build number. I'm not sure what that number is but I think the vin #s lower than 200000 had the weaker axles and were prone to breaking. There were several threads on here that talked about it. You can check the build number by looking at the last 6 digits of the vin. Hopefully there are others who can verify this info. I think they were recalled by Chevy tho so it might have been fixed. This problem was with the LS3 M6 Camaro.
Also the MAF...you want the MAF sensor to have a letter followed by a number. Those are the strong ones which won't have issues when you modify the car. The weak ones have a single letter. They are prone to issues. It is easy to check the last 6 of the vin for the axle thing. But I don't think the dealer will allow you to pull the MAF out to read it. I'm pretty sure that all these issues were addressed but you might wanna check in the search engine for more details. Outside of those two issues I have not heard anything. And I'd say try to get the optioned out SS. The newer ones have soo many options that even the 2010 2SS/RS feels a bit of a naked brute. But it is still a great car and you may just trade up in a year or two anyway. For low mileage cars try to get them under $25,000. Good luck. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black ZL1 Join Date: Apr 2013
Permagrin. It's contagious. No known cure.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
#7 | |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
Hmm let's see, third motor, 6th trans iteration, second diff, third set of axles, fourth driveshaft, lol, the list goes on, but this is a heavily modified car... The only issues I know of are the aforementioned output shaft on manual trans cars, and the shifter grind... If the car you're looking at had the output shaft issue, it's probably been long ago fixed, and the shifter issue is something that there are a number of fix's for... And this is all based on is it a manual or auto car... 2010, 2011 color is Red Jewell Tint, metallic... My color of car,
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
#8 | |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
#9 |
![]() Drives: 2010 CGM 2SS/RS - L99 Join Date: Mar 2013
I've had a couple of issues with my used 2010. They've all been fixed under warranty though. However, if I could do it all over again and the color option was available I would probably go 2011.
--------------------------------- Performance: Vararam CAI, Vmax Ported Throttle Body, GM Performance Dual Mode Exhaust (NPP), JRE Tune, Hotchkis TVS Stage 2 Track Pack, Vitesse Paddle Shifters, Vitesse Throttle Controller Functional: Hex Vents, Elite Catch Can, WeatherTech Digital Fit Mats, Escort Passport Max Cosmetic: Heritage Grill, GM Splash Guards, ZL1 Rockers |
#10 |
I.AM.
ABM is a great color. The fact that it's a 2010 wouldn't scare me off....I'd worry more about whether or not the previous owner took care of it.
The only other issue I can think of is the oil-cooler leak (not just on 2010's though).
#11 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
OP, You did not say if it was a V8 or V6. Most are assuming V8. There are different issues in the V6 & V8 models. I love my V6 and would not trade it for the world. There are a few issues to look out for though if you are looking at a V6. 2010 & '11 V6's had the LLT engine. I love the engine, but a few have had problems with sudden loss of oil & engines blowing. Also there are issues with timing chains stretching. If a V6 find out if the previous owner ran full synthetic oil & how often oil changes were done. If you are looking at a V6, check in the V6 LLT thread for more info. If it was well cared for you should be fine. Good luck.
#12 |
![]() Drives: 2017 Fifty 2SS w NPP Join Date: Dec 2011
I bought an early 2010 used no issues at all.
Also on he early 2010's there is a recall on the battery cable. Although this should have been fixed a long time ago at the dealership. |
#13 |
Planning to buy an SS with an M6 trans. I will get the VIN for one I am considering and see if it falls in the first 20k that may have the output shaft issue. Thanks for all the responses and info, feeling better about the 2010.
#14 |
Suffers Fools Poorly
Drives: 2010 SS/RS, CGM w/ Silver Stripes. Join Date: May 2011
If it's an SS and an early production model, the brakes squeak, A LOT
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot. |
| Tags |
| 2010, abm, problems |
