Old 10-22-2013, 08:33 AM   #1
DaJags85
Drives: 2013 2LS
Upgrading stock system
Hi all,
I've looked around the forum, but would like to ask a few questions. What do I need to purchase, as far as wiring goes, in order to install a 10" sub and amp to power it. I would also like to replace the factory speakers to some of higher quality. I have the base factory stereo in the 2013 2LS model. I plan to buy the ******** enclosure, a sub to fit and go from there. Thanks in advance.
DaJags85 is offline   Reply With Quote
Old 10-22-2013, 09:42 AM   #2
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
there is a wiring kit for ********, That is all I needed. Check there website, they have everything you need
meshamey is offline   Reply With Quote
Old 10-22-2013, 11:09 AM   #3
thxultra
thxultra's Avatar
Drives: Mean ass V6
If you have the stock radio (Non Boston) you will need rca wires, Loc (to convert from speaker outputs to rca, amp (I would get a 5 channel and power your new speakers with it also), speakers, enclosure and sub I don't believe ******** makes a kit for the non Boston system but I could be wrong.
thxultra is offline   Reply With Quote
Old 10-22-2013, 03:41 PM   #4
DaJags85
Drives: 2013 2LS
That's what I was afraid of. I was hoping they made one for non-BA systems.
Old 10-22-2013, 08:11 PM   #5
Old as Dirt
Old as Dirt's Avatar
Drives: 2013 Camaro
Start off with a sub... amplifier, wire kit(wire size depends on how many amps the system draws and can be checked by looking at the fuses in the amplifier.. volts x amps = watts, so if the amplifier has 2 40amp fuses, you can determine the real output of the amp is about 1100 watts and would require #4 gauge wire) and a line out converter w/RCA cables to grab the audio signal from the rear deck speakers.... you'll be surprised how much better it is.. then move up from there.. The LS alternator is good for 175 amps, and will be ok to run a system around 1200 watts without the need for a backup battery or cap.. above that, you will need to think about more power to keep the components happy..
Old as Dirt is offline   Reply With Quote
Old 10-23-2013, 08:30 AM   #6
DaJags85
Drives: 2013 2LS
Any line out converters that you guys would recommend?
Old 10-23-2013, 10:14 AM   #7
TeamTCA
TeamTCA's Avatar
Drives: 2010 Camaro 1SS/RS #21068
Yes, it is no big deal to grab the audio output at the rear speakers and tie (crimp or solder) a basic hi-lo level converter in. We do them all the time that way. For the remote
turn-on wire, we have found the easiest is to grab the accessory outlet in the rear of
the console (that is switched on with the ignition). Fairly simple install and several smaller sized (400-600w RMS sub amps) will even fit on the back wall behind the OEM trunk carpet.
Kenwood Excelon, Rockford Fosgate, JBL, Hertz, Audison, Illusion Audio,
Mosconi, Diamond Audio, Hybrid Audio, WetSounds, & more
TeamTCA is offline   Reply With Quote
Old 10-24-2013, 03:47 PM   #8
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
I think they do make one for non-BA systems. Check their web site.
Julio
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
Old 10-29-2013, 10:00 AM   #9
thxultra
thxultra's Avatar
Drives: Mean ass V6
Julio
Nothing for the Non BA systems this is because the ******** harness plugs into the factory wiring to the external amp which the stock (non BA) system doesn't have.
Old 10-30-2013, 09:38 AM   #10
got2gozoom
Drives: 2013 1LS-6sp-VictoryRed
Couldnt we buy the factory BA harness from the stock radio back to the amp and then FARK it?
By the way. A video from ******** said a new harness for Non-BA systems was now available on their site. I looked and did not find it.
got2gozoom is offline   Reply With Quote
Old 10-30-2013, 10:30 AM   #11
thxultra
thxultra's Avatar
Drives: Mean ass V6
Ya I looked on there site and couldn't find the one for the Non BA radio... Possible they have one coming.
Old 10-30-2013, 11:04 AM   #12
SimpleGreen
Drives: 2015 2SS/RS
Last time I asked about it Steve said they stopped selling it because it wasn't in high demand. Go figure.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler
1993 C1500 Single Cab Stepside 5.3L LS Swap
SimpleGreen is offline   Reply With Quote
Old 10-30-2013, 11:13 AM   #13
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yea, they used to sell it but stopped
Old 10-30-2013, 09:16 PM   #14
ric4044
Drives: 2012 Ashen Gray Camaro LS
hey....read the links and the attachment links included in the thread. I bought this from CMOREBASS and it works pretty good. You could probably build your own for around $100 bucks, but its pretty much plug and play. I'll even gift you the Kicker speaker wire to rca adapters since i have 2 laying around (just pay for shipping). I bought the ******** amp mounting board and everything sounds great and looks great. http://www.camaro5.com/forums/showthread.php?t=315787
ric4044 is offline   Reply With Quote
