![]() Drives: A White Car Join Date: Dec 2012
Turbos in place of mufflers, drone?
I've seen this set up on quite a few cars, not just Camaros but also C6s, R8s, etc. and I was wondering if you would get drone on the highway or around town with a set up like this? I'm looking for people with some personal experience with this, thanks!
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
![]() Drives: 2013 SS/RS Join Date: Jul 2013
The further you mount a turbo away from the manifold the less efficient it will be. Rear mounted turbos are by far my least favorite way to mount them! I've been in a couple C6 Vettes set up with kits like this and I wasn't impressed. Look at the AGP twin kit. Much better design!
As for the drone that will entirely be up to your exhaust choice. There are plenty of fairly free flowing quiet choices on the market. |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Varies Join Date: Dec 2009
The way I read your title was that you were looking to swap your muffler with turbos. Thanks JT |
![]() Drives: 2010 twin turbo ss Join Date: Nov 2012
I have twin turbos that mount under the manifold with a 3 inch magna flow catback. You can barely even hear the exhaust on the highway. With the turbos further back i would think itwould be even less noise
Thanks for the replies, yes Twin I was really just looking at noise level, not efficiency or peak power numbers.
#6 |
The Man in Black
Drives: 1969 Camaro 2010 Camaro 1SS Join Date: Apr 2009
Don't have rear mounts but my car is super quiet
#7 |
![]() ![]() ![]() ![]() Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
turbos are always going to have less sound as the exhaust is ran through the turbo's vanes,and there is no open track like with a cheap muffler than gives you than drone sound your not wanting. only sound you get is when the exhaust is dumped during decel which is just that cool hiss.
If your wanting a really good kit thats not that expensive unless you go crazy with the turbo design,call nick over at fastlaneturbo.com he has been building kits for over 20yrs..
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
now i have the same system and mine is super loud with tons of drone. difference? i have no cats, no mufflers, no resonators etc...so its whats done to the rest of the exhaust besides the turbo that counts. i would think with a stock exhaust and turbos out back the sound wouldnt be loud. sound more like a jet plane than anything.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
#9 |
Thanks for all the responses guys, I believe I've gotten the info I need! Have a good one!
#10 | |
The Man in Black
| Tags |
| drone, muffler, turbo |
