![]() Drives: Crystal red 2LT RS Join Date: Mar 2013
2013 vs 2014 v6, .5 seconds?
On chevy.com they say the 2013 does 0-60 in 6.4. The 2014 is rated at 5.9. Is that not all its cracked up to be or would it be awsome to have the new setup?
Feeling depressed.How can I make my 2013 6.0 flat? Looking at injen cai but that may not get me quite there... D cai's hinder power for short cold drives, say back and forth to work in the winter? |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Are you sure you aren't looking at the 2013 2LS 0-60? Fairly certain that the 1/2LT is still 5.9. The 2LS is 6.4 because of it's 2.92 gears, where as the LT cars are 5.9 because of the 3.27 gears. Pretty sure nothing has changed, you should be good to go as long as you don't have a 2LS
Teenage Dream Camaro
Drives: A Visually Stunning Camaro Join Date: Feb 2013
my 2013 1LT camaro has 3.27 gears?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '11 VR 2LT HHr Join Date: May 2011
Yes.. !
Read this thread its partly bout the transmission but it highlights the difference in rear end gears too http://www.camaro5.com/forums/showth...light=911medic
2011 Hhr
Formerly known as Silver85IrocZ !! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Have to agree with RacnJsn.
No way the 0 - 60 time has increased in the 2014 models versus the 2013 or prior models.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Look on page 15 of the 2014 brochure:
2LS: 0-60 6.4 seconds 1LS & LT's: 0-60 5.9 seconds No change from previous years.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
#7 |
That sheds light on it
Thanks for the post. So youre saying my 2013 lt will always show what gear its in if i have it in M? When i used tapshift before it wasnt but i guess it was in drive then...
#8 |
Yea it will appear on the DIC in the lower right hand corner
#9 | |
Using the paddles will show the gear no matter if in D or M, but if in D it goes back to showing D after a few seconds (10 maybe?), whereas if in M it will continue to show the gear after you use the paddles once.
#10 |
![]() Drives: 2013 Black V6 Auto. Chevy Camaro Ls Join Date: Sep 2013
Not cool I have a 2ls how can I make it to 6 flat or lower?? Can I change the gears or the whole setup to the ss setup and how much it would it be? anyone have an idea.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
You can switch over to 3.55 gears or yes you can get the SS setup. The SS setup will set you back at least 1000 dollars if you can do the work yourself. If you have to pay labor you're going to be looking in the 1500 dollar range.
#12 | |
Either way, you go, you're probably only saving a couple hundred bucks IF any savings at all by swapping to 3.55's vs swapping in a whole SS rear end. |
#13 | |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Black 2 LT vert Join Date: Jul 2013
i have a 2 LT. i earlier wondered why it was rated at 28 i hwy but LS was 30. i guess becuase of marketing reasons, too. you gotta read the fine print. i finally noticed that the gears are different in the 2LS verses the LT, same engine, but the 2.92 gears thus higher mileage over the 3.27 gears, which i think the auto SS is too.
| Tags |
| cai package, new camaro v6, performance |
