Old 10-23-2013, 09:46 PM   #1
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
GPI SS4 Custom VVT Grind on my car
Cold morning idle, about 900 rpms in this vid, warm idle is 850. This is on my car, cam/headers/udp/ported intake and tb/cai/no cats/gmpp mufflers. Makes 509 rwhp 460 rwtq with this setup! Track times coming soon! Move over 10.87, its gonna see 10.6-10.7 now!
Rhino79 is offline   Reply With Quote
Old 10-23-2013, 09:56 PM   #2
1989GTA
Drives: 1989 GTA Trans Am
Excellent numbers. What brand of dyno do you use?
1989GTA is offline   Reply With Quote
Old 10-23-2013, 10:01 PM   #3
Rhino79
Rhino79's Avatar
Land N Sea Dynomite. Kind of a mix between Mustang and Dynojet. It is more of a tuner dyno like the mustang, but doesn't read as low as they do. But it tends to read a little lower than a local dynojet we have in the area. I believe Howard up at Redline uses this same dyno. Its a good one with TONS of options and data acquisition.
Old 10-23-2013, 10:29 PM   #4
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
How's the drivability
Johnthegreat is offline   Reply With Quote
Old 10-23-2013, 10:33 PM   #5
Supercharged SS
Drives: 2010 Camaro
Rhino, how would this be with FI? I have a friend who is very interested in going vvt with his pd blower.
Old 10-23-2013, 11:04 PM   #6
Rhino79
Rhino79's Avatar
The VVT works awesome with FI Jamie. Both Centri and Roots style.
Driveability is good, needs a loosy goosy converter, this cam aint a baby one...lol
Old 10-23-2013, 11:08 PM   #7
Supercharged SS
Drives: 2010 Camaro
Thank you. He's very anxious to go vvt. The biggest prob is finding experienced people who aren't afraid of it. You are one of a few that can be trusted.
Old 10-23-2013, 11:47 PM   #8
epstein
Drives: SS/RS
Send a message via AIM to epstein
sounds real good sir!
epstein is offline   Reply With Quote
Old 10-23-2013, 11:54 PM   #9
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 10-24-2013, 12:15 AM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
Damn! I need to find someone local that would install this for me!
62nalide is offline   Reply With Quote
Old 10-24-2013, 12:30 AM   #11
Denis
Denis's Avatar
Drives: 2010 SS
Damn that sounds good.
Old 10-24-2013, 12:57 AM   #12
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Sounds great. Get that beast to a track!
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Unobtainium is offline   Reply With Quote
Old 10-24-2013, 01:03 AM   #13
1989GTA
IMHO your numbers are better yet. Most are taken on a DynoJet. You should do quite well at the track.
Old 10-24-2013, 01:44 AM   #14
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Talk to Grocerygetter. GPI just put a VVT SS3 cam in his vortech'd L99. Put down 620ish whp at i'm thinking 10psi. It made 110whp difference pre vs post cam. Nothing else was changed, except the tune, of course.
http://www.camaro5.com/forums/showthread.php?t=321282
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
