Old 10-24-2013, 08:14 PM   #1
CamaroW&b
CamaroW&b's Avatar
Drives: SS / ZL1 Kit retrofit
LS3 supercharger
Hey guys I hope you are doing well,
My friend has Camaro LS3 and he has some concerns about his project and I hope you guys can help him.
His LS3 engine is full stroker! He is planning to install a supercharger but he's confused between two types: the positive displacement or the centrifugal.
So do you have any ideas about the difference and which one is going to give him more power?
Waiting for your thoughts and suggestions.
Thanks
Kin
Mods:
Performance: ZL1 Corsa Catback Exhaust - CAI - Kooks 1 7/8"x3" Long tube headers.
Exterior: Full ZL1 body kit conversion.
Suspension upgrades
CamaroW&b is offline   Reply With Quote
Old 10-24-2013, 09:53 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There's magnacharger, whipple, KB, and a couple others in the posi dept. They sit on top of the engine and compress the air right before it goes to the engine. The charge air is cooled via a water to air IC. Cetri's are basically a belt driven turbo. They cool the air via a air to air IC. Centri's with a good IC will typically give you better IAT's. Which is best is purely dependent on what you want to do with your car. This has been debated NUMEROUS times. We have a FI section for you to search around in. If you want indepth info, i'd suggest you search google. There's TONS of info about both.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-25-2013, 12:18 AM   #3
CamaroW&b
CamaroW&b's Avatar
Thanks for your response. Google will be a good place to search for something but I thought it would be better to start asking in this forum to get info from experienced owners.
Mods:
Suspension upgrades
Old 10-25-2013, 08:01 AM   #4
Freyguy08
Freyguy08's Avatar
Drives: 2012 Camaro 1SS RS
Most of the time when I Google something about my Camaro it brings me to this site in the top 4 suggestions.
Comin' in hot!
Freyguy08 is offline   Reply With Quote
Old 10-25-2013, 10:00 AM   #5
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
I am not a supercharger specalist, but this is how I understand them.
the positive displacement: These are the ones that bolt onto the top of the engine, like the ones used on the ZL1. They require i little more work to install but take up a little less space.. They tend to be a little less drag on the engine when they are not being used. These are the preferred ones for manufacturers. They are great for low boost pressures, and they can't make huge psi number.
the centrifugal: These are closer related to a turbo charger then to a positive displacement supercharger. They are basically a turbocharger compresser with the exhaust housing replaced by a pulley. Much easier to install, and can make big numbers.
I'm sure that one of out modd gurus can exspand on this or correct anything I've miss stated.
Question, did he build the stroker motor for a supercharger? Ideally, you want to know that your going boost when your building the motor. To make big numbers, you want to lower the compression and do forged internals. If you plan on staying N/A you want to keep the compression high for more power. Also, you would want different CAM profiles for N/A verses Boosted.
Support Search & Rescue.
Get Lost.
MikeSVX is offline   Reply With Quote
Old 10-26-2013, 01:49 AM   #6
CamaroW&b
CamaroW&b's Avatar
Thanks for your response. I think this will help him to make up his decision.
appreciate it buddy.
Mods:
Suspension upgrades
Old 10-26-2013, 09:43 AM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
It would help to know a little more about his engine. What has it been stroked out to, what compression ratio is he at, what kind of power is he looking to make?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 10-26-2013, 12:28 PM   #8
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 10-26-2013, 03:11 PM   #9
47AJV8
Drives: A White Car
Really he should be looking at the 3 different types. Under PD: Twin-Screw and Roots and then non PD: Centrifugal. Centri and Twin Screw have the best top ends, centri builds boost with RPM so for EX: 6 psi and 6K redline ever 1K you're gonna make about 1 PSI of boost, twin screw and roots work on throttle position, they will build quickly up to max PSI at just under 2K RPM depending on their displacement and the engine, Twin-Screw is my personal favorite because you enjoy nearly as good of top end as a centri but with more power available lower down. I don't really like roots but it does make a ton of low end torque very quickly, but I've never found I needed any more seeing as the stock car can easily light up the tires and let alone with a twin screw on it. I would go with a whipple twin screw as KBs seem to run really hit IATs.
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
47AJV8 is offline   Reply With Quote
Old 10-29-2013, 08:30 AM   #10
Kelly@PCMofNC
Drives: 2010 RS/SS
We need more details.
Kelly@PCMofNC is offline   Reply With Quote
