Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Northwest / Pacific Northwest
Old 10-26-2013, 07:13 PM   #1
camaro1350
camaro1350's Avatar
Drives: 2013 Camaro RS 1LT, 6M
Alignment shop& timing the bushings
Any body knows a good shop that knows how to time the bushings and align the wheels on a lowered Camaro? I live in Albany OR. Thanks for your help
camaro1350 is offline   Reply With Quote
Old 10-27-2013, 01:28 AM   #2
Mobyd
Mobyd's Avatar
Drives: 2010 White 2SS/RS,01 F150 SuperCrew
theres this guy Eric in gig harbor he is good..google "enginehaus" to check his website etc.
Mobyd is offline   Reply With Quote
Old 10-27-2013, 05:52 PM   #3
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
I have never heard of timing bushings what does that mean? I have lowered plenty of Camaros but this term im not aware of.
firestone_ss is offline   Reply With Quote
Old 10-27-2013, 09:14 PM   #4
camaro1350
camaro1350's Avatar
Originally Posted by raymo1
It really doesn't matter with who or how you lower your car,Loosing the control arm pivot bolts and re-tightening them with the weight on the tires should be done.This is called timing the bushings,if not done the ride can be slightly stiffer and will cause the bushings to fail premature.This applies to the factory rubber bushings.Most aftermarket bushings pivot by design unlike the factory bushings.
Quote: The most important step in installing lowering coils is to time the OE rotational bushes to the new ride height. EVERY control arm bolt must be loose: front LCA, front radius arm, rear toe, trailing, inner lower... With the bolts loose drive the Camaro SLOWY around the lot and on to the alignment rack rails. With the weight off the car on the wheels tighten all the bolts. The bushes are now timed to your new ride height. This means your second set of springs the bushes are now working with your new Peddes lowering coils.
Here is the reason why you should time the bushing if the bushings are stock. It's not critical but it will wear your bushing prematurely. The hard part is finding someone who knows how to do it.
Old 10-28-2013, 11:44 AM   #5
firestone_ss
well that's interesting to say the least,but im not sold on the idea completely. I have never run into an issue and it seems that would add a cost to the project since most guys are flat rate.I algn the car after install and then have the customer drive it for a few weeks and bring it back when the springs settle and re align as needed. Still nice to hear about different ways of doing things thanks for the info brother
Old 10-28-2013, 11:59 AM   #6
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
I completely understand the concern for a flat rate tech. If I was a shop owner/manager/service writer, I would explain the pros and cons of doing or not doing this service and quote additional labor for it. Let the customer decide. It's not fair to the tech to require additional labor and not pay them for it. On the flip side, it's not fair to the customer to not do the job correctly, or at least offer to do the job correctly. Maybe this is something you should discuss with your shop manager.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
