Old 10-31-2013, 07:30 PM   #1
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
Need help removing the window shield crowl
Hello need to remove the window shild Crowl and heard its hard to do and I'm not sure how to do it. I looked in the DIY section and don't see it. Anyone know...
MARINE1991 is offline   Reply With Quote
Old 10-31-2013, 07:36 PM   #2
camaro2lt
camaro2lt's Avatar
There are a # of clips...take them out and the cowl will pull out...I think there are 3 to take out to get to the air filter
Old 10-31-2013, 07:58 PM   #3
MARINE1991
MARINE1991's Avatar
Yea I know the air filter one is no issue.. The one that has the wipers is the issue. Think the wipers have to come off not sure about it
Old 10-31-2013, 10:52 PM   #4
toNspahreP
Drives: SS
It doesn't unbolt. You have to cut it off...
toNspahreP is offline   Reply With Quote
Old 10-31-2013, 11:08 PM   #5
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Unbolt the wiper arms and look around for the push pins. Once the push pins are out, you can wiggle the cowl out. If it's being stubborn and not loose, you missed a pin or two.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 10-31-2013, 11:27 PM   #6
MARINE1991
MARINE1991's Avatar
Where the pins located thanks
Old 10-31-2013, 11:41 PM   #7
MARINE1991
MARINE1991's Avatar
Going to try sat to take it out
Old 11-03-2013, 06:07 PM   #8
MARINE1991
MARINE1991's Avatar
Just got done taking off the wipers and plastic Crowl what a pain should have made a DIY there is a trick to it the blades have to be vertical with the window. once I did that they came right off
Old 11-03-2013, 06:32 PM   #9
Bad Dad
Bad Dad's Avatar
Drives: 2010 2SS/RS , 2011 C6 Base Corvette
Where were the push pins and why are you removing the cowl?
SUICIDE BY RACECAR
Bad Dad is offline   Reply With Quote
Old 11-03-2013, 06:38 PM   #10
MARINE1991
MARINE1991's Avatar
It's the ones you take off to change the air filter and I'm sending them out to get hydro painted carbon fiber
Old 11-07-2013, 09:12 AM   #11
toNspahreP
Drives: SS
Oh, you mean the cowl cover. The cowl is the actual metal sheetmetal that frames where the wipers go. Makes more sense now.
