Old 11-01-2013, 06:26 AM   #1
b_williams_82
b_williams_82's Avatar
Drives: 2013 ZL1 #142
Driving in temps below 40*
I'll be driving through an area this morning where temps will be around 36* with wind chills around 25-30*. I'll only be in this area for about an hour or so. My garage the wheels are around 65-70*. Outside temp here this morning is 56*. Anyone think I'll have much of an issue if I'm just driving through?
Order # QHQWJF
Current Status: 4200 VIN 142
1100, (04/25/12): 2000, (05/21/12): 2500, (5/22/12): 3000, (5/22/12): 3100, (5/31/12): 3300, (5/31/12): 3400, (6/7/2012): 3800, (6/15/2012): 4000, (6/15/2012): 4104, (6/15/2012): 4106, (6/19/2012): 4150, (6/19/2012), 4200, (7/16/2012), 4300, (7/18/2012), 4B00, (6/15/2012) , 5000, (7/25/2012)
6000, Delivered to the customer (8/2/2012)
b_williams_82 is offline   Reply With Quote
Old 11-01-2013, 06:45 AM   #2
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
just be careful. i drive mine year round and even though im in florida i drive up north every year for the holidays and had no issues with cracking just a bit less traction.
joes407 is offline   Reply With Quote
Old 11-01-2013, 07:33 AM   #3
b_williams_82
Thanks. I'll just be driving through an area where the temperature gets that low then it will start to warm up again.
Order # QHQWJF
Old 11-01-2013, 09:53 AM   #4
knowitman
Camaro fan since birth
knowitman's Avatar
Drives: 2013 ZL1
Your tires should already be warm by the time you get to the area. You will have greatly reduced traction however. I think it is hard on the tires when they are cold after sitting and then you heat then up to quickly.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
knowitman is offline   Reply With Quote
Old 11-01-2013, 12:00 PM   #5
EFI
EFI's Avatar
Drives: something faster than you
You better watch out, these cars are not the same as other normal cars and they tend to melt on the spot as soon as they hit temps below 40* or rain or snow.
EFI is offline   Reply With Quote
Old 11-01-2013, 01:20 PM   #6
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
I've noticed that when temps are in the 40s it takes a good 20 to 30 minutes of hiway speed to warm up the tires. Even when warmed up they still don't have nearly the grip as when temps are 60+. I've taken the off ramp in 40 temps and going into the turn faster than I should like usual, oh Baby hold on because there will be some serious slip and slide. Thank god for the nannies! Saved my butt many a time!
Sent from my iPad using Tapatalk - now Free
Normagene is offline   Reply With Quote
Old 11-02-2013, 09:46 PM   #7
OldScoolCamaro
Cold weather driving will not be an issue as long as you drive easily, as in normal passenger car operation. If there is any issue with ice or snow, you will have a traction problem. If you are easy on the throttle, it will drive like any other car as long as the road is dry and clear. Don't think about performance at all under those conditions. The car is a 60 degree and up performer with compensation depending on road, air, and tire temps..
Old 11-02-2013, 11:53 PM   #8
onewaydave
Innocent Bystander
onewaydave's Avatar
Drives: 2013 ZL1 BRM/2002 35th SS/2009 GMC
Mine is in heated storage when the temp falls to 40 and I don't do the driving thing in any type of precipitation. So until next April it sits! Sad, but the ZL1 is not a winter car!
Living on the RaGgEd EdGe!
onewaydave is offline   Reply With Quote
Old 11-03-2013, 01:32 AM   #9
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
WEll look where you live,I think a lot of the cars we drive yr round might have issues up there north of parts of Canada ,lol I worked there back in the 80's and even summer it can be freaking cold... not really a great place to drive a ZL1 for more than a few months out of the yr...
being in texas on the gulf its a yr round car with only a few days a yr to worry about..I think 10 degrees would be fine just as long as your safe and try to stay out of the snow and ice..Salt sucks !!
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 11-03-2013, 07:43 AM   #10
Fast92RS
Fast92RS's Avatar
Drives: 2013 Zl1
I have driven the car a few times when the temps dropped below 40 in the mornings here and I will say the car really has no traction. Even after driving the car for a bit. The tires are also really loud until they warm up as well. I have to agree that when the temps are 60 plus the car really shines. Its one of the reasons I just put the car away for winter storage. The temps here are dropping at night and I don't want any problems with tire cracking.
2013 ZL1 Roto-fab cai, Apex catch can, Vmax LSA throttle body, Roto-Fab heat exchanger res, ATI balancer with 5% overdrive pulley, Stainless power 1 7/8" long tube headers.
Fast92RS is offline   Reply With Quote
Old 11-03-2013, 05:00 PM   #11
z28-conv
z28-conv's Avatar
Drives: '97 z-28 conv. 2013 BRM ZL1 conv.
I can tell you that when you are driving under 40 degrees the tires are harder. There is less traction as mentioned by a few others here. I definitely would NOT drive the car under 20 degree temps. There is a very good chance that the tires will actually split. It is also highly recommended by GM not to use the car in those kind of conditions. There are some other threads related to this subject somewhere here.
z28-conv is offline   Reply With Quote
Old 11-04-2013, 07:25 AM   #12
ZL1 TIBS
Drives: 1968 Camaro, 2012 ZL1
My tires were hockey pucks this morning (about 30 degrees). I am putting my winter tires on next weekend. Be very careful with cold temps until your tires have warmed up.
ZL1 TIBS is offline   Reply With Quote
Old 11-04-2013, 08:55 AM   #13
JANNETTYRACING
JANNETTYRACING's Avatar
I recommend you put it in PTM 1 Wet Mode, it really helps when temps are below 40
26 F here this morning on the way to work.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
JANNETTYRACING is online now   Reply With Quote
Old 11-04-2013, 10:01 AM   #14
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Don't haul butt everywhere. I'm like the guy in Florida, drive mine year round. Which means it hits in the 20's and 30's some, but not a ton. No major issues, just not dumping the clutch and hitting the gas.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
