Sand in my ignition!
I must have had sand and my pocket, and had it end up inside the knotches in my key....
so heres the deal, everytime i put the key in the ignition now, i get this grinding noise as i put the key in! any ideas on how to get the sand out? and could this damage any part of the ignition? Any help would be surely appreciated!
![]() Drives: 2012 Crystal Red Tintcoat RS Join Date: Apr 2013
Vacuum with a small attachment like a lint lizard and suck the sand out.
![]() Drives: 2013 2SS Join Date: Sep 2013
I'd try driving through a car wash with the windows open. Or maybe a little compressed air?
The gritos pollo!!!
If you have a air tank blow it out with compressed air
https://www.youtube.com/@FredJrsGarage
‘19 Silverado 3500 dmax ‘77 trans am ‘63 c2 Shopping for more Camaros |
#6 |
Austin LT
Drives: 1LT - Airaid,JBA Axleback,VMax PTB Join Date: Jun 2009
Get a can of compressed air at your local computer store.
#7 |
This is what I would do. The can comes with a tiny "straw" (like on a can of WD-40) that you can feed right down into your ignition key slot and blow out the sand (or whatever).
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
#8 |
![]() Drives: Saturn XR V6 Join Date: Feb 2013
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: COTW 8/29/11 2010 CAMARO Join Date: Jul 2009
#10 |
Assuming the ignition assembly is somehow encased in a "closed" cylinder of sorts (maybe it isn't), those little air cans produce plenty of "blow" for the job. If it is sand in there, it should be forced back out through the key opening. If not, OP just wants to get rid of the gritty crunchy noise when he puts his key in. So what if it just blows in deeper - So long as the key slot area if cleaned?
#11 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Sand is very tough to get out of anything...try the compressed air ..neither idea may work it might need replaced
#12 |
![]() Drives: 2012 2LT RS Join Date: Nov 2012
I think you should try sucking first and if that doesn't work then blow.
#13 |
![]() Drives: 2012 2SS/RS 45th Anniv 6 spd Join Date: Sep 2012
I say suck first then blow then suck, blow, suck,blow until it is gone then a little graphite to lube cylinder.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS, 2010 Mustang GT Join Date: May 2010
Like everyone is saying a vacuum should work. It probably got in there because the key portion had grease on it from the factory so over time it would stick to it in your pocket and get stuck in the ignition.
