Old 11-07-2013, 10:39 AM   #1
pony
pony's Avatar
Drives: 2011 2SS Convert; Color RJT
Do 2012+ have Oil coolers? Coolant return?
Considering doing a L99 oil cooler delete on my 2011 Camaro and notice that the upper radiator hose on the 2012 does NOT have the "T" that the oil cooler return line goes to for the 2011's. Do the 2012's have oil cooler? If so, where does the coolant return go now? Anyone actually done this delete without adding an auxially air oil cooler? If so, any issues?
Thanks for any info.
pony is offline   Reply With Quote
Old 11-07-2013, 10:55 AM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I recently looked into this as mine crapped out bigtime at the track. Dealer fixed mine but I will look for the parts to delete mine and have that as an option in the future.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 11-07-2013, 11:08 AM   #3
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
My 2012 2SS/RS has the oil cooler. There are lines that wrap around the sides of the block that go up and around to the passenger side from what I can tell.
They changed the RAD in 2012 SS models. The rad cap locations is now off-center and the upper rad hose is a 1-piece design without the break in the middle with the 'T' section.
If youd like, i can take a picture of my engine bay and post it here?
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 11-07-2013, 11:15 AM   #4
pony
pony's Avatar
Without seeing the 2012+ MY, I'm just trying to figure out where the oil cooler coolant return line goes too since it is NOT to the older upper radiator "t". Can you tell where they end and/or connect to?
Old 11-07-2013, 11:18 AM   #5
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Ill have a look and try and take some pics if i can make it out. Shouldnt be to hard..
Old 11-07-2013, 11:30 AM   #6
pony
pony's Avatar
Thanks. Would be appreciated. This pic from another members thread shows the routing on the 2011. The part #17 HAS to go somewhere
Old 11-07-2013, 12:31 PM   #7
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I noticed the same thing the other day preparing to install a aftermarket oil cooler. On my 14. The T has been eliminated and part #17 returns at the bottom of the radiator on the drivers side. See attached pic, it's the hose on the right.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 11-07-2013, 12:46 PM   #8
pony
pony's Avatar
THATS where that little sucker goes now. I'm guessing I don't have the option to route my Oil Cooler coolant return line to this location without replacing the entire radiator as well. I'll check to see if there is a "plugged" inlet port on my 2011 when I get home, but guessing there is not.
Not an issue if I decide to go ahead and delete the whole Oil cooler anyway. Still looking for input from those who have.
Old 11-07-2013, 01:16 PM   #9
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Yup i just checked mine too. #17 goes directly to the bottom of the radiator and the other end of the coolant port from the oil cooler actually goes directly into the drivers side of the block from what i could see when I just took a look.
Let me upload the pics I just took.
Old 11-07-2013, 02:14 PM   #10
White_SS/RS
Drives: 14 1LE
Are you simply wanting to get rid of the factory cooler set up or are you going aftermarket?
Only reason I'm asking is that it helps get your oil to temp quicker for improved emissions, power and engine longevity, however if your switching to an aftermarket cooler because you have oil temp problems like I do at the track then it's a good upgrade.
LMS Engineering
Old 11-07-2013, 02:32 PM   #11
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Here's the pics I just took...
Hopefully that helps. I added a couple others to show like the upper rad hose placement as well as the rad cap location..to kinda showcase the difference in the rad and lines.
Old 11-07-2013, 02:36 PM   #12
pony
pony's Avatar
Have a slight leak at the block connection; probably could be resolved with new gasket. However, considered removing everything all together for asthetics (looks). There seems to be a big swing from left to right as far as who thinks it's needed or not. I will only track my car on a rare occasion, and it is NOT driven in the fall/winter, so will NOT be needing an aftermarket oil cooler.
Old 11-07-2013, 03:25 PM   #13
White_SS/RS
Drives: 14 1LE
It will deffenately clean it up... factory 'cooler' is ugly.
LMS Engineering
Old 11-07-2013, 03:39 PM   #14
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
whats needed to take it off anyone know parts to replace the connections with?
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
