Old 11-07-2013, 08:22 PM   #1
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
9" or ZL1 rear or NEW Strange DANA 60
I recently put 3.91 gears and a Tru Trac in and ran 8 passes with my best 10.87@129 and then broke the Tru Trac. I am look for pros and cons of each.
The ZL1 is about 4500 with all the parts and the 9" is gonna be about 6000.i have heard many issues with the 9" such as vibrations and leaks but most come with a warranty,it that could be the older models not sure, the ZL1 is designed by gm for our cars and is a larger gear, but carries no warranty and has no options for an upgraded carrier but it may not need one.
I do plan on taking the car to the 9s eventually but not for awhile. any comments from experience would help.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline
Old 11-07-2013, 08:30 PM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
... Or pick up a ZL1 take out for less? $6K wow that's a lot.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Pro Stock John is offline
Old 11-07-2013, 08:36 PM   #3
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
You broke a TruTrac and youre only in the 10s? (I say ONLY in the sense of parts breaking, I know 10s are awesome!) Maybe Ill reconsider the TruTrac and just go Hammerhead.
2010 Camaro SS LS3 - No Modz
376LS3 is offline
Old 11-07-2013, 09:27 PM   #4
Turbo99
Turbo99's Avatar
8 passes, and about 400 miles I don't dump the clutch either. I'll post the video of the run before it broke.
Turbo99 is offline
Old 11-07-2013, 09:30 PM   #5
Turbo99
Turbo99's Avatar
About 1:30 I run in the video.
Turbo99 is offline
Old 11-07-2013, 09:41 PM   #6
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
To break a Tru Trac is off. Besides the Hammerhead, there's one forum member on here that runs 9's using the stock casing with a Tru Trac. In answer to your question however, both are good selections. On one hand, with the 9", some companies offer lifetime warranties, some don't. On the other hand, I can't recall anyone breaking a ZL1 rear end and the casing on those are completely made of iron.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline
Old 11-07-2013, 09:42 PM   #7
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
That didnt look abusive at all???? That sure doesnt sell me on TruTrac! Are you running a line-lock? My car doesnt stay that still during a burn out. Lol!
376LS3 is offline
Old 11-07-2013, 10:29 PM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I'm a fan of the nine inch set up... I run a wave track diff in a strange center section...
SSE 4 2SS is offline
Old 11-07-2013, 10:51 PM   #9
BigRed
BigRed's Avatar
Drives: SS RS SIM
I love my 9". I'm set up with a Gforce 9", strange pro iron pumpkin with a wave trac. Buy from Gforce and get a lifetime warranty.
I also have not had any of the leaking issues that you mentioned.
BigRed is offline
Old 11-07-2013, 10:52 PM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Do what I did. Find a used DSS 9" kit for $1,500 and sell your stock stuff for $1,000. Nothing beats a $500 9"!
SUX2BU is offline
Old 11-07-2013, 11:02 PM   #11
RRTX-SS
RRTX-SS's Avatar
Drives: 2010 2SS/RS M6
Damn!!!!! 1500 for a 9" I wish I could find those kind of deals......that's awesome man
2010 Camaro 2SS/RS
416 CI M6-LS3 Kenne Bell 3.6, Livernois Dual Fuel Pump Kit w/KB BAP, Futral Motorsports Blower Cam, SW 2"Headers, Zl1 Dual Mode Exhaust, Street Slayer Billet Twin-Disc Clutch,PFADT lowering springs and sway bars, Iforged Classic Wheels, AI Meth Injection, rx dual checkvalve catchcan, Innovators West 8-Rib pulley setup....690RWHP/701RWTQ @ 10 PSI-CALIBRATED BY KARGER @ SNL PERFORMANCE
1995 Camaro Z28 LT1 M6
383 Fully Forged shortblock
RRTX-SS is offline
Old 11-08-2013, 12:05 AM   #12
Turbo99
Turbo99's Avatar
I am not sure I follow the comment of "breaking a true Trac is off" are you saying it doesn't add up? I don't abuse my car I lift when I shift, it broke on a 1.51 60ft so whether it be 9s or not it was a solid hook and it broke. I was under the same impression as many that it would hold fine and the ring and pinion was going to be my weak link
Turbo99 is offline
Old 11-08-2013, 12:59 AM   #13
Turbo99
Turbo99's Avatar
So no one in this thread has had a vibration issue with the 9"?
What about weight difference between the 2, I would think the ZL1 stuff would be heavier since it is larger and an iron case, but does anyone have any numbers to put on it?
Turbo99 is offline
Old 11-08-2013, 08:40 AM   #14
BigRed
BigRed's Avatar
Drives: SS RS SIM
No vibration here. Mine is just as smooth as factory. U do not know the weight difference though. I remember seeing Casey from Gforce post some numbers a while back though. It's not as big of a difference as you might think though.
BigRed is offline
