Old 11-09-2013, 02:45 PM   #1
manu_b
Drives: 2010 Camaro inferno orange 2LT RS
Bad clutch feel
Recently developed a weird feel in clutch. Every time i release clutch slowly i get feeling of pulsation or flywheel rotating. it was not there before and its very prominent on cold start. Just changed oil and it did not help much. Is it something common or should I go to dealership?
manu_b is offline   Reply With Quote
Old 11-10-2013, 06:19 PM   #2
manu_b
Its bit worse now and it is definitely pulsating feel while pressing and depressing the clutch. could it be hydraulics or out of round clutch or flywheel? Here is the picture of the brake oil after 10000 Km. Is it supposed to get that dirty?
Old 11-10-2013, 07:05 PM   #3
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Might need to go to the dealer honestly.
I changed my fluid when I added my separate clutch reservoir and it really helped.
The clutch dust also contaminates the fluid.
Lil' Nasty is offline   Reply With Quote
Old 11-12-2013, 03:22 PM   #4
CamaroV6
Drives: Camaro V6 1LT Manual
I feel this as well...when my car had 30k it got really bad in which my passengers noticed it but it only happened on cold days and when the car was cold and would only happen for a couple of mins after the car had done its warm up cycle..I got the oil changed out just like you did and it fixed the problem. Now the car has 42k almost 43k and the clutch is starting to feel like that again as well on cold starts...Now with winter coming I hope it drops the temp to see if it starts to do it again if so im going to pressure my dealer into changing my clutch under warranty.
CamaroV6 is offline   Reply With Quote
Old 11-12-2013, 03:56 PM   #5
manu_b
Totally agreed , it's worse on cold morning. I will be going to dealership this week. I will let you know if something happens
Old 11-18-2013, 11:48 PM   #6
sreed009
Drives: 2012 Camaro LS
Have you heard back from the dealer? I am having the same exact problem.
sreed009 is offline   Reply With Quote
Old 11-19-2013, 06:00 PM   #7
manu_b
By the time I reach dealership, car warms up and they are not able to see problem. Once I leave car overnight then they will be able to diagnose it
