P2097 CEL CODE AFTER HFC INSTALL
Yes i know this is the V8 section, I'm posting this here because i didn't get much answers in the LFX section. Since the code is the same thing on all models I figured you guys could give me some answers.
But basically, I have had no problems with my vehicle (2012 LFX). Last Friday, I installed the Solo performance High Flow cats designed for the LFX. I've put on a good couple hundred miles on them since the install and then today as I was driving to California from Phoenix and my CEL Came on so I called OnStar and they said the code was P2097. I'm assuming this issue is due to the high flow cats, any suggestions? Also, I know what the code means, I'm just looking for some diagnostics/tips to resolve the issue.
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
![]() ![]() ![]() Drives: 2010 SS L99 Inferno Orange Join Date: Apr 2012
Are you using the O2 extensions? I would double check the sensors into the extensions and make sure everything is tight to start!
Yes I am using the o2 extenders, and everything seems to be pretty tight! I'm gonna double check though
| Tags |
| cel, o2 sensor, p2097, solo high flow cats |
