![]() Drives: 2010 silver 2SS/RS Camaro Join Date: Feb 2011
L99 horsepower mod help
Need some advise from my fellow L99 owners.My 2010 camaro ss currently has.
Kooks long tube headers with hi flow cats, Slp pulley ,KN cai,and a JRE tune.Looking to make my daily driver faster .what should my next mod be.Super charger? Cam? What is the best bang for the buck. |
![]() ![]() ![]() ![]() Drives: his wife crazy buying mods Join Date: May 2012
Cam most likely route I would go. But LS3 Conversion or VVT cam. Hmmm
Gone But Not Forgotten
What's a ls3 conversion.sorry new to this cam stuff
#4 | |
Drives: 2010 RS/SS Join Date: Dec 2010
A lot of people ditch VVT (variable valve timing) and DOD (displacement on demand), effectively rendering the L99 into an LS3 valvetrain wise. Whether to keep or delete VVT is a heated debate with people/shops on both sides of the fence, I would suggest doing your own research and deciding accordingly. We typically delete VVT here. You need to delete DOD at the very least when swapping cams as the L99 lifters won't be able to take it.
Rough parts cost on adding Magnacharger TVS 2300, (you need to include injectors/boost a pump since you have intake/headers) - around $7500. Pick up anywhere from 100-150rwhp roughly. $50-$75/per hp. All comes down to your budget and what you use the car for. Cams are great mods - nice bang for the buck without spending a fortune, great sound, you can always add a supercharger later - but depending on how big you go, can have less than great driveability and hurt MPG. Superchargers are nice also though, nothing like bolting on a ton of horsepower in just one day, absolutely no difference in driveability except that it hauls butt, doesn't really hurt MPG unless you're in it all the time. But hits that bank account a lot harder ![]() Check out some of our builds on our Customer Build Blog, gives you lots of ideas there! |
Yeah looked at doing a pro charger so it would fit with my custom roto fab covers I have.can I add a cam first or should I do supercharger first.
#6 | |
#7 |
![]() Drives: 2013 Camaro 2SS L99 A6 Join Date: Oct 2013
cam it. unless you have the money for a blower. a cam with install will be around 3k at most shops. a SC will run you around 9k with install. im debating on the cam as well, i may do the ls3 conversion but some people say dont do it and i still dont 100% understand why they say dont do it..
2013 2SS A6- Vette Doctor tuned-375whp 392wtq
cold air inductions intake stainless power 1 7/8" headers stainless works HF cats stainless works 3" retro chambered exhaust full de-badge of entire car |
#8 | |
#9 |
how about 3.73 gears and a 3200 stall?
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
#11 |
Haven't done any suspension work car only has 5000 miles.looks like cam is the way to go. Thought you had to do super charger first then cam.
#12 |
nah the super charger is kinda like the final frontier when it comes to mods haha thats why its the most money. get a cam setup that will allow for supercharging later on in case you get bored and want more power (which you will lol)
#13 | |
#14 |
![]() ![]() Drives: 2010 2SS/RS LS3 A6 Join Date: Mar 2011
I have an L99 and did the cam, GM Performance heads, Long tube headers route and it's fantastic for the buck! I've driven it that way for about a year and a half and decided I needed to step it up. Went with a nitrous kit. Best bang by far for the buck.
I also did the DOD/AFM delete when they did the cam. If you go that route, make sure they change your springs, rods, and your timing chain tensioner as the stock one is kind of the weak link in there. I went from 314HP at the wheels to 455 at the wheels cam, heads only. Pretty awesome little bump.
