Old 11-14-2013, 11:51 AM   #1
Decepticon21
Decepticon21's Avatar
Drives: 2010 Camaro v6
Heated Seats turning off?
Everytime I turn my heated seat on the thing stays on a minute then shuts off? Whats the deal anyone else have this issue?
Decepticon21 is offline   Reply With Quote
Old 11-14-2013, 11:57 AM   #2
RED2011_SS
Drives: 2011 SS
Send a message via Yahoo to RED2011_SS
The mat that gets hot under the seat probably has an open or burnt spot that intermittently touches. A good way to test is to turn the heated seat on but don't sit down in the seat and see if it stays on for a couple of minutes, if so then sit down in the seat and see if the heater then turns off. Could also be the module that controls the heated seats but from my experience the mat's usually burn through somewhere in the heater circuit over time.
RED2011_SS is offline   Reply With Quote
Old 11-14-2013, 12:09 PM   #3
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Mine does the same looks like a trip to the dealership for me.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 11-14-2013, 01:20 PM   #4
MikeOD
Drives: 2010 M6 2SS
I had this happen on the drivers side. I had to replace the heater elements...they were very cheap so I did it myself.
I needed like 20 or 25 hog rings (I forget)...did not remove the head rest...just pulled the leather far enough out of the way.
I tried to peel the old elements out, but they were taking foam with them, so I just left them and cut their wires off, and put the new ones right on top of the old ones. The seat looks perfect still, feels perfect still, and works again. The only special tool I needed was a hog ring plier from Amazon.
It maybe takes an hour and a half to do. The hardest part of the job was snipping the old hog rings out to get the leather off
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 11-14-2013, 06:41 PM   #5
Flaco2806
Flaco2806's Avatar
Drives: White camaro 2LT/RS
my heated seats do not turn on. can someone help me
Flaco2806 is offline   Reply With Quote
Old 11-14-2013, 10:54 PM   #6
The Crusher
still a kid at heart
The Crusher's Avatar
Drives: 2010 IOM 2LT RS with sunroof
SAME problem here...
passenger side works fine, but when i turn on the drivers side...the green light goes off after about 45 seconds....never heats up.
IM NOT taking it to the shop..i figured this might be something i can fix myself if only i knew what it was....from here it sounds like the heating element...hummmm
where do i get one?...dealer only?
2010 IOM 2LT RS with sunroof::mods include::AirAid intake::RX catch can and breather::JBA Headers::MBRP catback exhaust::BMR 1" lower springs and BMR sways::Trifecta Tune::MPD1 spoiler::black rims
The Crusher is offline   Reply With Quote
Old 11-15-2013, 07:45 AM   #7
Decepticon21
thanks for the help guys
Old 11-15-2013, 09:46 AM   #8
MikeOD
Drives: 2010 M6 2SS
I ordered them from a friend that works at a parts desk. PM me and I'll send you his info. He can also get you the hog rings...which are necessary. If you've never used hog ring pliers, order more than he says you need...they're very very cheap, and you might lose one or miss when you clamp it the first time or 2.
Old 11-15-2013, 11:21 AM   #9
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
wiring issue at connector more thank likely, sometimes you can repair the wiring if its not too close to the connector if it is a new element is in order.
firestone_ss is offline   Reply With Quote
Old 11-15-2013, 11:26 AM   #10
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
there is a sticky about how to DIY this really cheap and fast.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 11-16-2013, 12:30 PM   #11
mike 2010ss
Drives: 2010 SS
I'm not finding the sticky
Update: found it here--http://www.camaro5.com/forums/showthread.php?t=271981&highlight=seat+heater
mike 2010ss is offline   Reply With Quote
Old 11-16-2013, 06:26 PM   #12
2011ss/rs
2011ss/rs's Avatar
Drives: 11 ss/rs RJT w/Black Cherry stripes
Send a message via AIM to 2011ss/rs
Both of my heaters did it on a short trip but they haven't shut down since.
2011ss/rs is offline   Reply With Quote
Old 11-16-2013, 08:24 PM   #13
Merc
In The Circle
Merc's Avatar
Same here on my drivers seat. I can probably count the times on my hands how many times I;v turned them on. Pumpkin is usually tucked away by the time it get's cold.
Old 11-20-2013, 03:30 PM   #14
Goo
Goo's Avatar
Drives: Cayman S
I'm having this issue as well... also only on the drivers seat... Sounds like a bigger issue for the numbers that are having issues.
Thanks! The dealer has already changed the element once...
Goo is offline   Reply With Quote
