Old 11-15-2013, 12:08 AM   #1
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
AC pump broken clutch terminal what parts?
Hey Guy's can anyone tell me for 2010 SS if the ac clutch kit comes with the coil with terminal on it? I have been searching & cannot find what is listed in kit, so far I have determined it's part 92219540 or ac delco 15-40532. Also is a puller required to remove clutch on this model or just remove circlips for it to slide off, as i have accidentally broken terminal off when ac belt slipped over back of pulley. Or can the coil with terminal be bought separately? I hoping I don't have to de-gas system to fix or remove pump altogether.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 11-16-2013, 02:38 AM   #2
Kiwi_Camaro_2010
ok have got clutch off ac pump, does anyone know part No for ac clutch coil by itself?
Old 11-16-2013, 07:11 PM   #3
Kiwi_Camaro_2010
Here's some pic's of broken coil for ac clutch that I 'm after:
Old 12-16-2013, 07:22 AM   #4
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Any chance of using a dremel tool to expose enough conductor to solder a wire between the terminal pin and coil? Then cover with insulating, electrical epoxy. And maybe some black silicon. Not sure how hard that part is to get, but would think it's available.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 12-16-2013, 01:09 PM   #5
Kiwi_Camaro_2010
Hey thanks, I bit the bullet, bought new clutch kit & belt, left pump on car, easy to remove clutch, was nasty to put back on, but all done, nice to have cool air again since summer over here.
