11-15-2013, 05:12 AM | #1 |
Anyone running the zl1 fuel pump w/ adm module on a FI LS3?
Curious how effective it is and how much boost it will support.
11-15-2013, 06:36 AM | #2 |
Drives: 2011 2SS Join Date: Jun 2013
You will get many differnt opinions on this, mostly hp numbers some say 600whp others 650 usually people making about that much hp on FI LS3 are running from 8-to maybe 10lbs of boost I am switching to the zl1 adm setup very soon and will be running about 8.5 lbs of boost. I also think you can get away with the higher numbers like 650 if you have good injectors like IDs or FICs that can help keep fuel pressure up
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
11-15-2013, 08:22 AM | #3 | |
So far installed bbk Lt's w/ high flow cats, Borla s-type cat back , slp zr1 clutch kit, and the zl1 pump and amd module. |
11-15-2013, 08:30 AM | #4 |
Drives: Red 2010 Camaro 2SS L99 Join Date: Apr 2010
So does the ADM module eliminate the need for a fuel pump booster(MSD)? Or would there still be benefits from the booster in addition?
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers Exhaust Clip: http://youtu.be/c_quv8eoVNQ |
11-15-2013, 08:38 AM | #5 | |
Others please reply if I'm wrong.
11-15-2013, 08:56 AM | #6 |
Drives: 2013 TT ZL1 Join Date: Jun 2013
Send an email to Andy & ask him. I know PMJ on here is pushing that setup really far at around 800rwhp, he was running it that way at The Texas Mile, you could pm him also.
11-15-2013, 09:01 AM | #7 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
The combo wasn't enough for me on E85 at ~600 whp but E85 requires ~30% additional fueling. Livernois dual pump I still see a pressure drop also, waiting for the Squash returnless system to be released. 9 psi boost with ID850's.
11-15-2013, 09:22 AM | #8 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
works fine for me through an auto and big converter showing 628whp...mid 10 second range in the 1/4 I guess...we run 1kft here and it runs 8.8@116. Rhino said no concern when he was tuning it.
-John S.
11-15-2013, 11:58 AM | #9 |
Im running it with now issues . Make sure you install it and have your tuner put a tune for it
Brian |
11-16-2013, 09:08 AM | #10 |
Drives: 2012 Camaro SS Join Date: Oct 2011
607rwhp and no issues. Vortech V3si
11-23-2013, 11:48 AM | #11 |
11-23-2013, 12:03 PM | #12 |
instigator
btw...with headers added and 654whp the car picked up a bit over a tenth and 3mph. fuel still fine...pullied down 2 more psi and went to like 675...fuel pressure dropped 3psi. so we put it back at the 654 boost and tune.
-John S.
11-23-2013, 12:11 PM | #13 |
This set up can still benefit from an MSD fuel pump voltage booster.
www.jannettyracing.com
11-23-2013, 01:41 PM | #14 |
My Whipple came with the MSD booster. I installed it even though several folks here said it was not needed. I installed the ZL1 fuel pump and ADM pump controller and had Ted tune it. I am holding 68psi fuel pressure at the fuel rail at 9psi boost consistently at all rpm's using the injectors that came with the Whipple. No dyno numbers though.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
