Old 11-16-2013, 01:21 PM   #1
BTRSS
BTRSS's Avatar
Drives: 2011 Camaro SS Supercharged
Strut brace install
I have an 11 SS and I bought the GM strut brace + the install kit off ebay. I've seen a bunch of `10's and `11's with this strut brace and install kit and am wondering if there is a DYI post for this.
BTRSS is offline   Reply With Quote
Old 11-16-2013, 03:21 PM   #2
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Do you have the pre-drilled holes on top of the shock tower, if you do all that should be needed is to bolt it on......I'd suggest using red Loctite on the bolts.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 11-16-2013, 05:08 PM   #3
BTRSS
BTRSS's Avatar
No, the strut tower on the 2011's weren't built for the strut brace (except the conv were) so there are holes.
Old 11-16-2013, 08:32 PM   #4
DARK AGE 53
Drives: 2010 SS
Looks like you may need to drill some holes then, didn't the brace come with any directions on how to install it?
Old 11-16-2013, 09:35 PM   #5
RKCamaro13
RKCamaro13's Avatar
Drives: 2011 Red 2SSRS A6
I bought the strut tower brace, and I have a 2011. Mine already had the holes drilled for the brace. I would think they were all pre-drilled?
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Magnuson Supercharger, ID850 Injectors, Alky Methanol Kit, Livernois Fuel Pump Roto-Fab CAI, SW long tube headers, CNC ported throttle body, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Custom Interior.
RKCamaro13 is offline   Reply With Quote
Old 11-16-2013, 09:54 PM   #6
The Beard
The Beard's Avatar
Drives: 2013 2SS HWSE M6
The early 2011s did not have the strut towers that accept the factory strut tower brace. I had a late model 2011 that did.
The Beard is offline   Reply With Quote
Old 11-17-2013, 01:36 PM   #7
BTRSS
BTRSS's Avatar
My 2011 had the dome tower strut with no holes like the later model 2011. The kit came with instructions but I was hoping someone might have taken a video of the install. Guess I'll be the first.
Old 11-17-2013, 02:05 PM   #8
DARK AGE 53
Drives: 2010 SS
I checked to see if I could a write up or video of the install but came up empty handed, if you can it probably be a big help to others in the future.....if you do a write, take a lot of pics.
