Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
OUT OF ZL1 Door panels, All i have is a non matching set of door panels BLue and gray!
Drives: 2014 Z51 Corvette Join Date: Apr 2011
What about the Black Dash pieces?
Sorry these are just for the doors. I do not have any dash parts
Thanks.
Also have coupe and convertible door pulls from the 2012-2014 camaro!
#6 |
LRDV8R
How hard is it to install these door inserts?
#7 |
RIP Betsy ( Vitara )
I have yet to install but I have removed my current panels (cloth) to get mine painted and I can tell you it's pretty easy. I did it in a single car garage with very little space to open the doors so if you can do it in an area with full swing access it will make the job even easier.
The hardest part was disconnecting some of the switches. Installing is just the dismantle in reverse so I'm confident it will be super easy to do.
First retrofitted 2014 mylink. |
#8 |
easy! Just remove the door panel and remove the old inner panel
#9 |
LRDV8R
Forgive my ignorance, what is ABL ???
#10 |
![]() Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
Correct me if I'm wrong. Ambient blue light
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
#11 |
Yea but the abl can also be in red. On the zl1 panels the abl is red
#12 |
Let's go Rangers!
I'd really like the door inserts. Anyone have a DIY on how to swap the door inserts?
I just found the DIY for the dor panels. Are you suppying the screws to insert the panels? |
#13 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
What are you wanting for the door pulls (convertible)?
#14 |
60shipped for the set they are brand new
