Old 11-19-2013, 05:19 PM   #1
CMRO.SS
CMRO.SS's Avatar
Drives: 2016 C7
True Track Posi
Hello. Im pretty new here to camaro5. I'm just wondering if anyone has the true track posi mod with 3.91 gears. My car is ar JRE now getting them installed. I have heard you that you lose conering with the posi
2012 Camaro SS 712 rwhp sold. 2015 ZL1 sold.
CMRO.SS is offline   Reply With Quote
Old 11-19-2013, 08:28 PM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
CONGRATS on your ride and Welcome to our happy little corner of the net, and to Camaro5. There is a BIG fridge on the back porch with anything you can think of in it...help yourself...of course only take what you can LEGALLY have. Make yourself at home on one of the big fluffy couches, kick your shoes off, put your feet up on one of the tables, yes we are allowed to do that, mom's, dad's, wives', husband's, girlfriend's and boyfriend's here don't care....and take it easy.
Welcome!!
Old 11-19-2013, 09:38 PM   #3
Vengeance Graphix
Vengeance Graphix's Avatar
welcome
Old 11-21-2013, 09:23 PM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
CMRO.SS,
Greetings and welcome to the forum! How have you been enjoying your Camaro?
William R.
Chevrolet Customer Care
Old 11-21-2013, 09:24 PM   #5
Supercharged SS
Drives: 2010 Camaro
Drives like stock. Don't worry about it.
Old 11-21-2013, 09:26 PM   #6
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Welcome! That is totally untrue. You lose cornering ability with a Locker, not a posi. Posi's release during turns, Lockers dont.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 11-22-2013, 11:07 AM   #7
GlennP
Drives: 2011 Camaro 2SS
Haha, thats awesome. My car is at JRE for the same exact thing!
Are you on the Dyno today? I got an erroneous call that "my" breather wasnt working properly and I was like uhhhh...I dont have one!
Turns out it was on the gray Camaro and I have the black one :P
GlennP is offline   Reply With Quote
Old 11-22-2013, 12:46 PM   #8
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
My buildout will end up about where your at with mods. I am curious if JRE recommended billet caps or LPE cover for your power level?
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Cuda7050 is offline   Reply With Quote
Old 11-22-2013, 01:10 PM   #9
Supercharged SS
Drives: 2010 Camaro
The caps are a good idea bc they are cheap and since you already have the rear open you may as well do it all once.
No real need for that cover.
Old 11-22-2013, 02:40 PM   #10
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I think the cover is a good idea. it allows for an extra half quart of fluid and applies additional torque on the caps.
Posted from Camaro5.com App for Android
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 11-22-2013, 02:51 PM   #11
Supercharged SS
Drives: 2010 Camaro
I run the stock cover with no issues. Didn't that cover have venting problems?
Old 11-22-2013, 09:42 PM   #12
Chris82xx
Chris82xx's Avatar
It did, that issue was worked out and so was the clearance issue that they had. I did it for that extra security. I remember doing my research that with hard launches, the OEM caps weren't holding up. Then I heard a few JRE caps breaking, so I figured I would add the cover and the allen bolts torqued down on the caps.
811RWHP/719RWTQ
Old 11-23-2013, 02:22 AM   #13
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Its amazing how hard it is to find a local shop that will install billet caps. Ive called all the 4x4 shops around here and none of them have machine shops. Is this not a required upgrade on rock crawlers and such? I figured this was a common mod. Got the TruTrac in the mail a couple days ago. Just need an installer!
Old 11-24-2013, 10:00 PM   #14
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
tru trac
I got my tru trac from jre last year and put about 14 k on it .
The car is a daily driver and it works great.
ZOOK is offline   Reply With Quote
