11-29-2013, 04:27 PM | #1 |
Drives: 2014 1LE Camaro, 95 Z28 Camaro Join Date: Jun 2011
2014 Heat extractors on hood
So i took the bottom part off to see what it would look like.
Love the way how it opens it up. My question for you is do you think there is anything bad about doing this? I dont drive it in the rain and i would cover that part up when i was the car. Anything else im not realizing might happen?
2014 1LE 2SS Camaro Recaro seats, Custom Cam, Kooks LT headers, CAI intake, Z/28 Spoiler, Z/28 Belly Pan, Z/28 Brake Air Ducts, Stainless Steel breaklines, BMR Toe Rods and Trailing Arms resulting in 482.49 RWHP
11-29-2013, 04:39 PM | #2 |
Drives: 2010 Camaro 2SS/RS White S/C Join Date: Aug 2010
There should be nothing wrong with that as long as no water falls on it.
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty |
11-29-2013, 04:41 PM | #3 |
Drives: 11 SS Join Date: Oct 2013
More heat extraction now, just be careful not to get caught in a downpour.
11-29-2013, 05:24 PM | #4 |
I don't see how it can cause any issues, especially with the engine cover in place.
Best regards, Tyler 888-308-6007 |
11-29-2013, 06:42 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Why?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
11-29-2013, 07:16 PM | #6 |
Stick it in your trunk, along with any tools you made need to install it (probably just pops in)... just in case.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
11-29-2013, 07:43 PM | #7 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
While it is logical to think "heat rises, less stuff there is better", the car is also in motion and there are high and low pressure areas.
I too wonder if the baffles are just for water management or if they had a function In either case I don't think you're actually increasing the amount of heat removed. I think it seems that way.
11-30-2013, 05:09 AM | #8 | |
Drives: 2014 camaro ss ,1967 chevelle ss, Join Date: Sep 2013
It takes air from grille however Im not seeing holes in core support that line up with ports on scoop |
11-30-2013, 10:39 AM | #9 |
2016 Camaro 1LT 2.0T
Drives: Nemesis Join Date: Feb 2011
Looking at the pic, it does seem that the port holes in the heat extractor piece are only to allow water drainage towards front of the car. I'm not seeing how the car brings air in through them. Unless the new wider front fascia lines up with the port holes, this means that the air from under the car must rise up, around the engine and exit through the vents. I fail to see a significant amount of added down force from the new vents. Hex vent for win!
11-30-2013, 10:52 AM | #10 |
Obsessed and Loving It...
Drives: 2013 1LE-SS Join Date: Jun 2013
The air flow over the hood causes a pressure difference that draws air out of the engine compartment. Taking the base off actually would help at least some small additional amount of air escape as long as you don't get a hug amount of water in there.
11-30-2013, 12:10 PM | #11 |
Drives: 2011 2SS Synergy Green Join Date: Nov 2011
I'm not running the drain pan on my '11 with a '14 hood. There is a TREMENDOUS amount of heat escaping through the vent at stop lights. It's crazy to see heat mirages bellowing our from the middle of the hood at a stop haha
11-30-2013, 03:05 PM | #12 | |
I know what you mean. Everyone again ill be sitting at a light and you can see the heat rise out of the hood. I havent had a chance to see if its different since i that part off. Maybe it will be like a steam geyser.
05-07-2014, 04:30 PM | #13 | |
Friction is a drag.
Drives: 2014 Camaro 2SS/1LE Join Date: Dec 2013
You never really learn to swear until you learn to drive..
05-07-2014, 04:42 PM | #14 |
Drives: ( . )( . ) Join Date: Feb 2010
Just being carefull, or just use a trim remover tool. I used a small flat head screwdriver and carefully worked it until i could pull it with my fingers.
